Water Level Low In Toilet Bowl In Flushometer Toilet. - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-05-2017, 07:57 AM   #1
Rewards Points: 2
Water level low in toilet bowl in flushometer toilet.
I have a flushometer toilet.I recently replaced the diaphragm assembly because my toilet didn't flush.My water level in the toilet bowl is too low.How do i restore the water level to the normal level in the bowl?.
falconi is offline   Reply With Quote
Old 07-05-2017, 11:24 AM   #2
Rewards Points: 2,720
Re: Water level low in toilet bowl in flushometer toilet.
Typically by raising the float cylinder on the shaft (turn screw thing if I recall correctly).
Go to their site; I'm sure they've how to adjust section.
bob22 is online now   Reply With Quote
Old 07-05-2017, 03:38 PM   #3
hkstroud's Avatar
Rewards Points: 6,694
Bob22 is referring to adjusting the water level in the tank.
You stated that the water level in the bowl was not at the same level as before replacing the fill valve.
There is a small tube that attaches to the fill valve and connected to the top of the over flow pipe. See REFILL tube
The water coming out of that tube and flows down inside the overflow pipe is what refills the bowl.
Insure that that tube is properly attached to the fill valve and the overflow pipe.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Tags
bowl , flushometer , toilet , water level
Toilet Water Level Varies PolishPete Plumbing 6 09-30-2015 02:16 AM
Toilet Bowl Mystery roztom Plumbing 5 01-31-2014 11:05 AM
leaks on rear base of toilet & water supply valve Nospammer Plumbing 1 08-16-2012 03:21 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Toilet bowl losing water czars Plumbing 2 10-28-2010 07:56 PM
