Water Leaking Into Eljer Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
Old 08-17-2016, 04:53 PM   #16
Rewards Points: 294
Re: Water Leaking into Eljer Toilet
Thanks, how difficult was it to repair the whole thing using korky?
Did you have to remove the tank from the bowl? Or can repair be done while everything stay at its place?
helpme81 is offline   Reply With Quote
Old 08-17-2016, 05:04 PM   #17
Rewards Points: 5,520
The black ring visible in the kit is the new seat that adheres to the old seat with the silicone adhesive sealant seen in the kit. Directions are on the packaging. Drain tank, and follow the directions on package is all that's need to be done.
Old 08-17-2016, 05:18 PM   #18
Rewards Points: 1,854
Use flusher fixer by fluid master. You remove old flapper. Drain all water and dry clean the plastic the old flapper rested on then the flusher fixer has a putty on its bottom that makes a seal against the old flapper seal. Works fine last a long time!!!!
http://www.walmart.com/ip/Fluidmaste...&wl13=&veh=sem
Old 08-17-2016, 05:37 PM   #19
Rewards Points: 294
SeniorSitizen, can you please share the link for the whole kit?
Ghostmaker, have you tried and used that one? That looks like a really neat idea
Thanks so much for the help, I truly appreciate it. Today after adjusting the chain height, there's no leak/drip so far, but it's not being used extensively either.
I am going to monitor it and will report back.
Thanks again folks
jmon likes this.
Old 08-17-2016, 06:19 PM   #20
The second picture is the complete repair kit. I purchased mine at a plumbing supply. This link is very similar.
http://www.korky.com/flappers-flush-...lve-repair-kit
Toilet Still Leaking After Replacing Gasket, Bolts, Fill Valve, Flush Valve wheeee Plumbing 24 08-11-2017 08:57 PM
toilet still leaking tstex Plumbing 21 04-15-2016 09:12 AM
Strangely Leaking Toilet... OhmZoned Plumbing 4 01-14-2012 11:55 AM
water keeps leaking in toilet bowl dan ashby Plumbing 10 03-15-2011 11:15 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
