Water Leak Under Foundation Block - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree11Likes
Old 12-21-2017, 11:56 PM   #16
Peace be with you
DR P's Avatar
Rewards Points: 1,860
Re: Water leak under foundation block
u should find out what new water supply line professionally installed will cost and their timing to get your water back...2/3 of actual costs is split between excavation equipment and materials and final 1/3 is labor so not so sure you will save a bunch... either way u go - good luck
Peace
Lo's Den likes this.
DR P is offline   Reply With Quote
The Following User Says Thank You to DR P For This Useful Post:
Lo's Den (12-22-2017)
Old 12-22-2017, 12:02 AM   #17
Rewards Points: 22
I understand from what you guys are saying that this old Iron pipe is no good. However we can't really afford a big project like that at the moment. If i wanted to just patch the current leak and make do with the old pipe for now.. What would you guys recommend? Thanks so much
Lo's Den is offline   Reply With Quote
Old 12-22-2017, 12:21 AM   #18
Peace be with you
DR P's Avatar
If you don't ask for a price\quote you will never know how much it will truly cost...
I recommend you find your leak source, completely expose & dig that section out (above and below pipe, forward and aft for several feet); identify the type piping involved, take pictures, post your findings.
Peace
Old 12-22-2017, 12:34 AM   #19
Rewards Points: 22
Peace
I will work on it more tomorrow and will update with pictures Thanks again!
Old 12-23-2017, 08:10 PM   #20
Rewards Points: 22
Thanks so much for all your help. We have decided after all things considered, to get estimates after Christmas.
Old 12-29-2017, 10:44 PM   #21
Rewards Points: 22
Total cost was $350 and the actual leak was about 4 foot over from where the water was springing up. The pipe leak was in the front yard about 2 foot from the wall, not under the house. Just wanted to update. Thanks again fort the help!
SPS-1, Nealtw and DR P like this.
Can't drain electric water heater dubina Plumbing 35 08-02-2017 08:07 PM
Help with hot water katiejosh811 Plumbing 13 12-28-2016 05:52 AM
Stone foundation repair in Philadelphia cb_philadelphia Concrete, Stone & Masonry 1 11-03-2016 02:39 PM
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 07:26 PM
