Water Leak From Septic Vent Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2016, 01:14 PM   #1
Rewards Points: 12
Water Leak from Septic Vent Pipe
I am curious about a slow dripping leak coming from the vertical pipe that is mounted to the seweage pipe going out to my septic tank. I recently noticed that there a slow dipping leak coming from the rubber gasket around the vertical pipe as you can see in the picture. I've attached two pictures, the pvc pipe in question is the one on the right. Please let me know what the cause could possibly be. I'd like to have a plumber come out, but I am wondering if it is could be something simple I could tackle or not. Thank you for any and all suggestions.
takea125 is offline   Reply With Quote
Old 05-12-2016, 01:39 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,678
Re: Water Leak from Septic Vent Pipe
That looks like a compression fitting like you normally see under a sink. If it is leaking it is loose or has a bad gasket in it. I'm no plumber but I don't think that is the proper fitting to be using there.
I would be stubbing it up and using a no hub Fernoco type coupler.
Old 05-12-2016, 04:02 PM   #3
Rewards Points: 1,866
I would be more concerned why your water level is that high there. Thats a rubber cast iron to plastic hub adapter.
Ghostmaker is online now   Reply With Quote
Old 05-12-2016, 07:19 PM   #4
Rewards Points: 18,800
Remove those plugs and clean out the trap yet?
If you remove the caps and water runs out you have a septic issue outside the home causing the leak.
Slab leak advice needed! Help MsTFT Plumbing 23 01-31-2013 03:34 PM
Copper Pipe Leak Caused by Hard Water? Asathd Plumbing 20 07-09-2011 09:06 PM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
Leak found - need advice (Vent pipe) krooser78 Plumbing 0 03-29-2010 02:49 PM
