Water Heater Vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-06-2016, 08:41 AM   #1
Rewards Points: 850
water heater vent
what is the most you can angle a vent for a gas water heater. im having my water heater moved to a laundry room that has aluminum awing that is ribbed. it has a high, 4", rib then low, so trying to make it water tight is a challenge.
hotrod351 is offline   Reply With Quote
Old 05-06-2016, 08:48 AM   #2
Rewards Points: 18,960
Re: water heater vent
Google "metal roofing vent boots"
Old 05-06-2016, 09:19 AM   #3
Rewards Points: 850
i do roofing so i know about vents. the problem is it a awing and running a vent though the middle you cant get to it, sure cant walk on it. its a 60 year old awing, not designed fro any type of pipe to go though.
Old 05-06-2016, 09:37 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 248
You can run it horizontal (1/4" per ft rise) but it may change the diameter of the vent. You would need to consult sizing charts.
Water heater issues?!? NJdan Plumbing 1 06-04-2015 07:42 PM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Why can't a water heater vent be extended? Toller Plumbing 6 02-21-2013 08:26 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
