Water Heater Temperature - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2016, 02:42 PM   #1
Rewards Points: 1,128
Water heater temperature
My water heater has a few settings(4,3,2) between not and very hot. My water is only getting warm when set to hot. Should I have to set it between hot and very hot to get hot water? Thanks
Mstrlucky74 is offline   Reply With Quote
Old 02-13-2016, 03:18 PM   #2
Rewards Points: 3,230
How old is wh and has it ever been flush and maintained yearly.
You can try turning it up a little more see if it helps then turn it back down.
If you have to use the very hot setting to get hot water somethings wrong with gas control module. Ive seen the temp probe on them with lots of sediment build up which can affect the way they work.
jmon is online now   Reply With Quote
Old 02-13-2016, 05:27 PM   #3
Originally Posted by jmon
How old is wh and has it ever been flush and maintained yearly. You can try turning it up a little more see if it helps then turn it back down. If you have to use the very hot setting to get hot water somethings wrong with gas control module. Ive seen the temp probe on them with lots of sediment build up which can affect the way they work.
Flushed??? Not sure if it was before we bought house 8 years ago and we never did it. Water heater is 19 years old.
Old 02-13-2016, 05:44 PM   #4
Rewards Points: 582
could be bad control, could have crud built up on thermostat inside tank, could have broken drop tube... however at 19yrs old ...think replacement..
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
jmon (02-13-2016), joecaption (02-13-2016)
Old 02-13-2016, 05:56 PM   #5
Agree with ben. I wouldn't stick too much money into fixing it up. Sometimes flushing this late in the game can make matters even worst. Chances are after 19 years, you're never going to get all the sediment build-up out anyway.
At least you have somewhat hot water for now. Start budgeting for a new one.
Old 02-13-2016, 06:35 PM   #6
Rewards Points: 18,806
Not sure how it works there but to pass inspection the temp. at the tap can not be more then 120 deg.
Have to agree your at least 4 years beyond expected life on most water heaters.
Would have been longer if you would have drain some of the solids out of the tank twice and year.
Water Heater Constantly Failing/Replaced DroidGuard12 HVAC 6 04-11-2012 03:41 PM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 09:47 AM
Gas water heater poor temperature control nanoplane Plumbing 3 01-24-2010 08:29 AM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
