Water Heater Supply Line Connector Type - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2017, 09:17 PM   #1
Rewards Points: 18
Water Heater Supply Line Connector type
The current water heater uses a corrugated copper supply line connector, and I think it would be wise to replace it when installing a new water heater. Lowes doesn't carry copper, only stainless steel.
I understand that copper to galvanized is a no-no, but is it ok to use a stainless steel to connect the existing copper pipes?
Should I use teflon tape on new connection to a new water heater?
HolyCow is offline   Reply With Quote
Old 02-01-2017, 09:24 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,246
Re: Water Heater Supply Line Connector type
https://www.copper.org/applications/...derations.html
Old 02-01-2017, 09:44 PM   #3
Rewards Points: 18,964
If you have galv. supply lines I strongly suggested you make plans on replace them.
100% of the time the close up and rust on the inside reducing flow and are going to leak at some point.
First thing I do when looking at a house to buy and it has steel supply's is deduct the cost to replumb it with PEX.
Old 02-02-2017, 07:03 AM   #4
Plumber
TheEplumber's Avatar
Replace your supplies with the same or the stainless ones. Both will do just fine.
The nuts on the flex have washers similar to a hose connection. So thread tape will only help reduce friction while tightening. Use it or a teflon based pipe dope. A small amount is all you need.
Old 02-02-2017, 12:12 PM   #5
Rewards Points: 1,932
New tanks come with a dielectric nipples. So you have no issues connecting the copper lines.
Old 02-04-2017, 03:53 PM   #6
Rewards Points: 648
I hope you are talking about the stainless corrugated lines and not the stainless flex lines. If it's the stainless corrugated lines, you'll be fine connecting them to anything. Don't use the stainless flex lines.
taylorjm is offline   Reply With Quote
Old 02-04-2017, 11:48 PM   #7
Rewards Points: 6
Why not use flex stainless steel lines? They make the for water heaters.
http://www.homedepot.com/p/Eastman-3...8259/205971718
paul100 is offline   Reply With Quote
Old 02-05-2017, 11:59 AM   #8
Rewards Points: 648
They are glorified garden hoses. Basically a hose covered with stainless steel braid. For awhile there were issues with them bursting or leaking. They rate right up there with the slip on connectors for a water heater. The only time I have even used the corrugated stainless ones were making connections to my well expansion tank and water softener because they could need repairs done or movement. A water heater isn't moving and if you have copper pipes, there's no reason to not sweat it in place.
Old 02-05-2017, 12:02 PM   #9
Rewards Points: 648
I personally don't care for even the stainless corrugated ones because they rely on a garden hose type rubber washer connection and it's easy to over tighten them and cut right through the rubber washer. Or for it to degrade over time. I wish they made the same type of corrugated lines only with a pipe connection that actually used a tapered thread connection you could tighten up and not rely on a rubber washer. Of course, I'm not an engineer and know it would probably present a problem to have a swivel connection that doesn't use a rubber washer. Or it would be expensive to make.
Old 02-05-2017, 06:10 PM   #10
Not sure how you are or if your even a licenced plumber but your post are way off base!
Never once had an issue using braided flex lines.
So much easier for a a DIY.
Old 02-05-2017, 08:06 PM   #11
Rewards Points: 648
Really? Way off base huh? So because YOU haven't had an issue with SS flex lines, then they must be ok right? Try reading this then let me know.
https://www.classaction.org/water-supply-lines
http://www.lemurzone.com/rfg/index.p...omment-page-1/
http://www.consumerclasslawyersblog....sands-dollars/
http://www.werc.com/2014/11/10/commo...-water-damage/
Old 02-05-2017, 08:09 PM   #12
Rewards Points: 648
You are more than welcome to use whatever you would like, and as I said in my post "I personally don't care" for them. But to attack me, and my credentials because you don't agree with what "I personally" don't agree with, is very unprofessional.
Old 02-05-2017, 09:05 PM   #13
Rewards Points: 6
I agree with you. Never saw a problem with braided lines. Been using them for years on washing machines.
Old 02-06-2017, 01:32 AM   #14
Rewards Points: 80
We use braided hoses (by OEM spec) on heating systems. Some of which hit well over 100psi at about 140*f..... Usually flared fittings though, but I've seen a few rubber seals. Who am I to argue with the OEM?
Cheers!
supers05 is offline   Reply With Quote
Tags
supply line connector , water heater
New-ish electric hot water heater blowing fuses. roasted Electrical 33 01-11-2017 01:24 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 09:12 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
