Water Heater Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-29-2017, 10:26 PM   #1
Rewards Points: 18
Water Heater replacement
Iím replacing an electric water heater thatís in a closet in the kitchen of our single story ranch. The current heater doesnít have a drain pan and the pressure relief valve isnít connected to a drain. Iím going to get a Bradford White that has a diameter of 22Ē. What size of drain pan should I use? Can I run pvc from the pressure relief valve to drain into the drain pan? Can I drain the drain pan directly into the crawl space? Any other tips for this project?
HolyCow is offline   Reply With Quote
Old 01-29-2017, 10:44 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,870
Re: Water Heater replacement
Where are you located.... there are codes requiring the valve drain directly outsde....
MTN REMODEL LLC is offline   Reply With Quote
Old 01-29-2017, 11:10 PM   #3
Rewards Points: 1,054
If your pan has a proper drain, a 24/26" pan should be fine. Not sure what your code requires, but CPVC should meet any code for a T&P and pan drain. Not sure if a crawlspace is OK to drain to. I'd run it out past the foundation and have the end where I could see it and easily clean it out. I've seen them blocked up with mud dauber nests. Maybe use a screen on the end of it. Fl code requires CPVC & PVC pipes outside to be painted.
clarenceboddick is offline   Reply With Quote
Old 01-29-2017, 11:16 PM   #4
Rewards Points: 18
Central Indiana (Hamilton County).
Tags
water heater
Replacement water heater... Toller Plumbing 5 06-08-2015 05:44 PM
A Water Heater, an Outlet, a Cable and a Breaker Koldhammer Electrical 1 02-19-2015 04:43 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 10:43 PM
Electric Water Heater Issues - Water Too Hot after tstat replacement and Sulfur Smell marman4880 Plumbing 4 08-05-2010 04:25 PM
