Water Heater Question - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree6Likes
Old 11-08-2016, 11:33 AM   #1
Rewards Points: 312
water heater question
have a gas water heater. makes a 'popping' sound when it is re-heating water. I assume this is from sediment build up. what is the best way to remove the sediment? hoping someone has some good pointers...
KPDMinc is offline   Reply With Quote
Old 11-08-2016, 12:33 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,272
Re: water heater question
Drain the tank and flush it out.
supers05 likes this.
Old 11-08-2016, 12:51 PM   #3
Rewards Points: 312
Thanks - I know it needs to be drained and flushed. was hoping for a little more detail on what steps to take...
Old 11-08-2016, 01:53 PM   #4
Rewards Points: 5,482
It's just a fact of life that the heater is over the hill and is calling for a youngster to take its place.
I've read that heating the water very hot makes draining more successful. Let's think about that for a few seconds. It has a dip tube that goes to near the bottom and if the dip tube is good the water draining becomes cold very quickly. If the water remains hot the dip tube has probably shot craps.
Old 11-08-2016, 03:26 PM   #5
Pretty good video here...
Old 11-08-2016, 04:04 PM   #6
Rewards Points: 4,746
You don't need to drain it unless you're moving it, flushing it is enough. That said, if it's several years old and you've never flushed it, you should waive off and leave it alone.
stick\shift is offline   Reply With Quote
Old 11-08-2016, 04:36 PM   #7
Rewards Points: 312
so, what are the steps for just 'flushing' it? We just purchased the house, water heater is pretty new.
Old 11-08-2016, 05:04 PM   #8
When you drain it, you stop the incoming water and open the drain at the bottom. Flushing is half the work - you don't shut off the incoming water and let a few gallons out. If the water is murky, keep doing it until the water runs clear.
Old 11-08-2016, 05:15 PM   #9
Rewards Points: 312
would you need to shut off the power source? gas?
Old 11-08-2016, 07:53 PM   #10
Rewards Points: 80
No, just don't close the incoming water valve.
Cheers!
supers05 is offline   Reply With Quote
The Following User Says Thank You to supers05 For This Useful Post:
KPDMinc (11-09-2016)
Old 11-09-2016, 07:13 AM   #11
Rewards Points: 3,264
(short answer) No, do not stop the incoming water and open the water tank drain until after you turn off the water heater heat (gas or electric). Otherwise the heater might kick on and self destruct.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
Old 11-09-2016, 01:47 PM   #12
Oso954's Avatar
Rewards Points: 1,600
For more help contact Plumber San Jose.
What are you doing, pimping your company ?
Recommending that a San Diego area resident call a San Jose Plumber makes no sense.
KPDMinc likes this.
Oso954 is online now   Reply With Quote
Old 11-10-2016, 01:37 PM   #13
Rewards Points: 38
When a gas water heater (WH) starts making the "popping" sound, it is time to replace it. The "popping" sound is from a layer of sediment in the bottom of the WH, which has solidified into a limestone type rock. You have waited too long to do the required maintenance on your WH. Replace it and remember to drain the sediment out of the new WH at least once a year.
SHR Plumber is offline   Reply With Quote
Old 11-10-2016, 03:28 PM   #14
Rewards Points: 312
its only a couple years old according to the tag. and its not a loud popping sound... more like a maybe a ticking...
Old 11-10-2016, 07:43 PM   #15
Rewards Points: 3,208
If it's that new, then it's still under warranty and may be a normal sound. Call the manufacture and ask them directly about the noise or look in your owners manual under the troubleshooting section. They should be able to help you further.
Newer energy saver models have heat traps on the top that may cause that issue. Nothing really to worry about. If it turns out to be a heat trap issue, You can replace them with ordinary dielectric nipples available at any big box store.
jmon is online now   Reply With Quote
Electrical Hot Water Heater Question Twister Plumbing 8 07-09-2014 07:11 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
Tankless water heater question Bennylava Plumbing 3 03-22-2013 05:40 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
