Water Heater Pressure Relief Valve Let Out Some Water, But Not Constantly Leaking. - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-09-2016, 09:59 PM   #1
Rewards Points: 484
Water heater pressure relief valve let out some water, but not constantly leaking.
Los Angeles location.
My tenant turned up the gas water heater thermostat, but the water is not quite scalding hot yet.
Tenant called me and said there's a puddle of water where the pressure relief valve drains to. I'm thinking it's because they turned up the water heater temperature.
Would it be normal for the relief valve to open up even if the water wasn't near-boiling?
Other than the small puddle of relief water, the relief valve is not constantly leaking or dripping, and works fine when I manually open the valve.
Is this normal? Should I be looking to replace anything?
pman626 is offline   Reply With Quote
Old 12-09-2016, 10:54 PM   #2
hkstroud's Avatar
Rewards Points: 6,684
Re: Water heater pressure relief valve let out some water, but not constantly leaking
That is a T&P relief valve. It is there for safety. It opens if temperature or pressure gets too high. Read the metal tag under the lever. It probably says 150 psi and 210 degrees.
When water is heated it expands. That means pressure goes up. If you do not have a check valve on the cold water input line, and you do not have a pressure reducing valve with a check valve built into it, this excess pressure moves back up the cold water line.
However, if you have a check valve on the cold water line or the PRV has a check valve, the excess pressure has no where to go and the T&P valve will open.
If you have a check valve or a PRV with check valve, you need to put an expansion tank on the cold water input.
Frankly it sounds like the tenant has set the temperature too high.
hkstroud is offline   Reply With Quote
Old 12-10-2016, 06:34 AM   #3
Rewards Points: 2,074
Tell your tenant to back off the setting a little bit wait a day and watch the next day if it's still weeping back off a little more. Sounds like he's got it to hi and water press/temp is causing the relief valve to open.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 12-10-2016, 08:19 AM   #4
Rewards Points: 3,290
Do you have an expansion tank (usually abovet the water heater attached to the cold inlet pipe)?
Every new tankful of water that is heated will expand. Up until now there may have been enough give in the system (such as the water heater tank sides bulging a tad and compromising the glassl lining). Perhaps this time someone used most of the tankful in one sitting and then no one used hot water for several hours so that the expansion during heating of the next tankful to the new higher set temperature was great enough to trip the temp & pressure relief valve.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
Old 12-10-2016, 10:44 AM   #5
If it was heating ok before he turned it up I would say that is the likely cause. You have to be a detective in this field. If cutting back don't work then something else is going on with it.
Old 12-10-2016, 02:41 PM   #6
Rewards Points: 484
no expansion tank. I don't think the tank is common in these parts.
Yeah, I've never heard him complain about it till now. Then I noticed he dialed up the temperature because the bathroom at the far end of the house was not getting hot water fast enough.
I told tenant that hot water takes a few minutes to travel that far.
I just wanted to make sure the water heater parts were functioning normally, because I was about to replace the TP valve, but common sense told me it was functioning normally upon testing.
I also wanted to make sure that occasional water discharge was not too serious.
Old 12-10-2016, 03:37 PM   #7
That was good advice because no matter how hot the water is it will still take time to get to the other end of the house. messing with the thermostat won't help it . What it will do is make it hotter once it gets there.
Old 12-10-2016, 07:10 PM   #8
Rewards Points: 1,956
You should caution the tenant that if he has children, the temperature he has set the heater at can be dangerous.
ChuckF. is offline   Reply With Quote
Running A Water Heater Pressure Relief Valve To A Sump Pit hellohello Plumbing 8 02-27-2014 10:15 PM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Water Heater Pressure Relief valve has opened and leaking water out, kskouby Plumbing 2 02-12-2013 06:56 AM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 02:35 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
