Water Heater Pees On Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-27-2016, 01:41 PM   #16
Rewards Points: 5,526
Re: Water heater pees on floor
A little water discharge could be condensation. A half gallon, replacement should be considered.
Old 03-27-2016, 01:45 PM   #17
Rewards Points: 3,216
You found your problem.
Agree with mike. No, not normal at all for water to come out of schrader valve.
As mike said, time for a new expansion tank. If it is new, take it back and get another one.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
everyman789 (03-27-2016)
Tags
water heater
Vacuum breaker with tankless water heater? braman Plumbing 3 04-07-2013 01:40 AM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 09:17 AM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
