Water Heater Pees On Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-27-2016, 11:14 AM   #1
Rewards Points: 14
Water heater pees on floor
Yesterday I installed a new gas water heater with a power vent. Since then, twice the relief valve opened and about two cups of water came out. Not violently, just ran out. There is an expansion and on the supply line. Any ideas?? Thank you. Alan
everyman789 is offline   Reply With Quote
Old 03-27-2016, 11:20 AM   #2
Rewards Points: 3,208
Re: Water heater pees on floor
Welcome to the forum everyman.
What's the temperature set at? Is expansion tank set at your incoming water pressure, usually around 55-60 psi.
Could you post a picture of your set-up, thank you.
jmon is online now   Reply With Quote
Old 03-27-2016, 11:22 AM   #3
Retired Moderator
Rewards Points: 7,174
You may need to install a pressure tank---they are inexpensive and simple to install.
Old 03-27-2016, 11:34 AM   #4
Rewards Points: 14
The temp is set at about 130 degrees. It was at 140 and I turned it down to see if that helped (it did not). The expansion tank doesn't seem to have an adjustment on it. I installed it when I replaced the water heater last time, several years ago. It's rather small, a cylinder measuring eight inches in diameter and ten inches tall. It says on it "Pre-charge pressure 40 psi." Also "Water Heater Safety Tank." There's a nipple at the bottom. I'm ancient and technologically incapable of posting a picture. The tank is up high, about ten feet from the heater, and in a 3/4" copper line supplying the heater
Old 03-27-2016, 11:37 AM   #5
Rewards Points: 14
I do have an expansion tank on the supply pipe. Thanks. Alan
Old 03-27-2016, 11:43 AM   #6
Rewards Points: 14
Thanks, jmon. Do you think I need a bigger/better expansion tank? Alan
Old 03-27-2016, 12:35 PM   #7
Maybe. How many gallons is your water heater?
Old 03-27-2016, 12:39 PM   #8
The small expansion tank you have is good up to about 50 gallon water heater. Anything bigger than that you need to upsize your expansion tank.
Old 03-27-2016, 12:45 PM   #9
Expansion tank on water heater should be set to your incoming water pressure. Usually around 55_60psi. Verify what yours is first. Check at any hose bib. Easy check with water pressure gage.
There is a schrader valve On bottom of expansion tank where you can add more air. You will need to turn off incoming water and relieved pressure for accurate readings.
Old 03-27-2016, 12:46 PM   #10
Rewards Points: 14
40 gallons.
Old 03-27-2016, 12:48 PM   #11
Rewards Points: 14
Thanks VERY MUCH, jmon.
Old 03-27-2016, 12:49 PM   #12
The one have should be good enough. 40psi is probably too low. You need to set it at your incoming water pressure. See if that helps. Just a suggestion.
The Following User Says Thank You to jmon For This Useful Post:
everyman789 (03-27-2016)
Old 03-27-2016, 12:50 PM   #13
You are welcome everyman. Hope you get it running right soon.
Old 03-27-2016, 12:59 PM   #14
Rewards Points: 14
I checked at the Schrader valve with a bike tire gauge ~ it reads about 70 psi, and water came out when I made the reading. Is this normal? Alan
Old 03-27-2016, 01:24 PM   #15
Retired Moderator
If water came out of the Schrader valve--the bladder inside the tank has ruptured.
Time to replace that one.
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
everyman789 (03-27-2016), Ghostmaker (03-27-2016), jmon (03-27-2016)
Tags
water heater
Vacuum breaker with tankless water heater? braman Plumbing 3 04-07-2013 01:40 AM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 09:17 AM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
