Water Heater Leaking At Cold Water Inlet Outside. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-26-2015, 12:28 PM   #1
Rewards Points: 30
Water heater leaking at cold water inlet outside.
The cold inlet pipe between the wall and the water heater is leaking outside of the wall. It's not the PRV but is from the cold side. I went to the hardware stores with pictures and nobody knew why the extra small pipe is coming out from the cold inlet. Why is it leaking outside and what is it for?? I thought is was the PRV so replaced it and it's not the problem. It'll fill the metal bucket in about a day and a 1/2. Thanks for your help.
Water heater leaking at cold water inlet outside.-dsc06379.jpg   Water heater leaking at cold water inlet outside.-dsc06381.jpg   Water heater leaking at cold water inlet outside.-dsc06378-copy.jpg
DesertRat is offline   Reply With Quote
Old 01-26-2015, 01:13 PM   #2
78Vette's Avatar
Rewards Points: 580
I have a expansion tank close to my WH. Makes me think, this may just be a expansion valve it's connected to, but i'm just guessing.....The Pro's will be along shortly!
78Vette is offline   Reply With Quote
The Following User Says Thank You to 78Vette For This Useful Post:
DesertRat (01-26-2015)
Old 01-26-2015, 03:42 PM   #3
Rewards Points: 3,456
Looks like something that was used for an ice machine or something that needed a water hookup. Idk, just guessing.
Can you post a close up pic of that t coming off the incoming cold water line. Looks like some sort of saddle valve. Thanks.
jmon is online now   Reply With Quote
Old 01-26-2015, 04:30 PM   #4
Rewards Points: 30
Hope this helps.
Thanks for your military service and defending this great nation.
The Following User Says Thank You to DesertRat For This Useful Post:
jmon (01-26-2015)
Old 01-26-2015, 04:46 PM   #5
Oso954's Avatar
Rewards Points: 1,868
I think that is a water heater backflow preventer with the drain/vent piped outside.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
jmon (01-26-2015)
Old 01-26-2015, 04:49 PM   #6
Very possible.
Old 01-26-2015, 04:50 PM   #7
Rewards Points: 30
It started leaking about 6 moths ago. I've been in this house now for about 5 years. Why now??
Old 01-26-2015, 05:07 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 258
Yep, I agree for the most part. I bet its something your local code requires.
What does the metal tag say on it?
Have checked your water pressure?
BTW- I dont see a PRV, I think you meant TPR (temp/pressure relief) valve.
Old 01-26-2015, 05:14 PM   #9
Rewards Points: 30
I don't think it's a local code requirement 'cause my neighbors don't have that setup on their water heater.
How do I check my water pressure?? The water does flow out fast at first than slows down to normal from sinks in the house.
I guess TPR is the right term. I guess you knew what I meant though.
Old 01-26-2015, 05:39 PM   #10
Rewards Points: 30
The metal tag reads:
Other side a blank.
So far even the hardware stores, the plumbing stores, and even the store that sells water heater and parts are at a lost. They all say that they never seen that setup before.
Old 01-26-2015, 05:51 PM   #11
A "Handy Husband"
rjniles's Avatar
Rewards Points: 892
It is a pressure expansion relief valve used in lieu of an expansion tank. It vents water to relieve excess pressure. If you don't want to deal with the drain water replace with an expansion tank.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following 3 Users Say Thank You to rjniles For This Useful Post:
78Vette (01-26-2015), Ghostmaker (01-26-2015), jmon (01-26-2015)
Old 01-26-2015, 05:54 PM   #12
Plumber
Rewards Points: 258
http://www.airdelights.com/W-Model-BVEC.html
Buy a pressure test gauge at your hardware store. Screw it on your hose bib and take a pressure reading.
Also check the temp at your faucets.
It could just be that the valve failed.
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 01-26-2015, 06:04 PM   #13
Rewards Points: 30
I see. But why is it on my water heater and not the neighbors and the hardware store is lost about what it is??
Also why is it leaking now??
Old 01-26-2015, 06:07 PM   #14
Oso954's Avatar
Here is a link to the spec sheet on it.
http://dar.proflo.com/darmanager/Que...=SPECIFICATION
As it is a combination valve, you might try operating the shut off valve a couple of times. With a little luck, you might clear some trapped sediment.
The Mfg.s phone number is on the bottom of the sheet. You could call them and see who handles their product in your area.
Old 01-26-2015, 06:14 PM   #15
Rewards Points: 1,942
This is a thermal expansion control device. It is doing its job dumping excess pressure out that small pipe. Like Javiles said if you do not want that install a hot water tank expansion tank and remove the expansion control device.
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 09:47 AM
Leaking Pipe above hot water heater with pics notarock Plumbing 9 07-30-2011 08:29 PM
Water Heater - Water reversed, hot is cold, cold is hot acaciaavenue Plumbing 5 12-09-2009 11:00 AM
