Water Heater Leak, Replace Pressure Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2015, 01:48 PM   #1
Rewards Points: 48
Water Heater Leak, replace pressure valve?
Residential gas water heater
Leaks near the pressure valve towards the top of the tank, I say "near" because I cannot see if it is coming from where the valve connects to the tank, or if the leak comes from the tank itself.
Here is a vid of the water heater with everything off and drained enough so that it is not leaking
Here is a vid after I turn the cold water going into the tank on, then the leak starts once the tank if filled up enough to reach the valve, if it is important, the gas is off and electricity off so the tank is NOT be heated
peequi is offline   Reply With Quote
Old 12-10-2015, 02:23 PM   #2
Rewards Points: 3,208
Looks like its leaking from the threads. If so, take out tpr valve clean it, put some tape on threads reinstall. Check for leaks. Might as well replace it with a new one . just a suggestion.
If leaking directly from the valve, check exp tank.
jmon is online now   Reply With Quote
Old 12-10-2015, 02:26 PM   #3
Rewards Points: 48
Yeah it is over 10 years old, so mind as well replace it.
Expansion tank works fine.
Thank you for your reply.
The Following User Says Thank You to peequi For This Useful Post:
jmon (12-10-2015)
Old 12-10-2015, 05:05 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,034
Ayuh,..... It's possible, the threads in the tank rusted out,.....
Ya might be lookin' at replacin' the whole shebang, rather than just that pr valve,...
Do ya have a torch,..?? are ya handy enough to sweat copper pipe,..??
I don't see a union in the line, so ya gonna pull a joint apart, 'n sweat it back together after,....
That's just to change the pr valve,...
Pressure release valve on gas water heater leaking minimally amakarevic Plumbing 7 03-12-2015 06:59 PM
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Brand new water heater TPR valve spraying fetzer85 Plumbing 50 03-20-2013 11:32 PM
Problem with pressure release valve in hot water heater? da_man Plumbing 3 08-16-2011 08:14 AM
