Water Heater Leak Fixable? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-22-2015, 03:17 PM   #1
Rewards Points: 374
Water heater leak fixable?
My water heater has a small leak coming from the top. It looks like it might be coming from a crack in the white gasket (does this piece have a different name?). Pics attached.
Can I fix this? If so, what to do I need to do?
Thanks in advance,
CG
Water heater leak fixable?-wh1.jpg   Water heater leak fixable?-wh2.jpg   Water heater leak fixable?-wh3.jpg
costgeek is offline   Reply With Quote
Old 08-22-2015, 04:02 PM   #2
Rewards Points: 5,348
The plastic is just a bushing around the metal collar. It has no water sealing function. The nut you see inside the plastic is the sacrificial anode. By the bump on top, it's a magnesium metal anode.
Has that anode ever been changed?
How old is the unit?
How good are you at plumbing?
You can pull out the anode to check how much of it is left. Maybe Teflon tape part of the threads to see if the leak stops.
Are you sure the water is coming from the anode area?
Ron
B. Franklin 1759
Old 08-22-2015, 04:27 PM   #3
Rewards Points: 374
Well I can't tell how old the unit is. The only date on it says 1992 but it seems to be referencing code it complies with. It's been here since I've owned the house since 2012.
There is a fair amount of corrosion where the hot and cold connect to the tank. Upon closure look there is moisture at both these connections. The hot definitely has it's own source of water (the moisture doesn't connect to anything else. Between the cold and anode it hard to tell which is the source but the cold seems more likely?
I've done a bunch of 1/2" in various places in the house and replace the main valve myself so I'm comfortable doing plumbing. But I've never worked on a water heater before...
Old 08-22-2015, 04:46 PM   #4
It's dead Jim. Best to start over before it floods your house
gassyplumber is offline   Reply With Quote
The Following User Says Thank You to gassyplumber For This Useful Post:
SHR Plumber (08-24-2015)
Old 08-22-2015, 05:20 PM   #5
Rewards Points: 582
is sure looks like a leaker to me....replace it...
Old 08-22-2015, 05:43 PM   #6
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
Think that I would go with Gass and Ben on this with a replace.. if it is back into the 90's and there is leak and questions on just where it is from .. better to look at a replacement sooner rather than later before the dam breaks on the thing and makes a mess.
Akpsdvan is offline   Reply With Quote
Old 08-22-2015, 07:23 PM   #7
Has it rained there lately? Could water have come down the vent?
If you dry off the area, does the water come back quickly?
How long have you owned the property?
Ron
B. Franklin 1759
Tags
leak , water heater
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 05:00 AM
