Water Heater Leak - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 3 Post By artie1
Old 12-05-2016, 10:58 AM   #1
Rewards Points: 18
Water heater leak
I have a gas water heater that has a pinhole leak on the inner flue pipe. It's close to the top, I can see it clearly. Is there any posible way this can be repaired? Patched?
artie1 is offline   Reply With Quote
Old 12-05-2016, 11:09 AM   #2
Rewards Points: 6,288
Re: Water heater leak
I personally would not repair a pin hole leak in my flue pipe, especially if it were due to old age or defective manufacturer.
If you must, as in some instances, J B Weld comes to mind as a possible solution.
Old 12-05-2016, 11:12 AM   #3
Rewards Points: 18
The heater is just over 7 yrs old. I know the best thing to do would be a new one but just trying to buy some time.
Old 12-05-2016, 11:37 AM   #4
hkstroud's Avatar
Rewards Points: 6,692
Since you said pin hole leak I assume that you mean a pin hole water leak. If so, there is no repair. Not even JB Weld. If you could apply the JB weld you would only be applying it to corroded metal. If you could stop the leak now it won't be long before the water pressure would cause another leak next to it.
Leaks in water heater tanks always occur at the welds use to make the tank. No one is quite sure why but if one weld has deteriorated to the point of leaking, then other welds are have also deteriorated.
The risk of trying to patch a leaking tank is that next week you will come home and find your house flooded.
Time to replace before you create a bigger problem.
hkstroud is offline   Reply With Quote
Old 12-06-2016, 09:59 AM   #5
Rewards Points: 18,952
Post a picture so we can see what your seeing.
Old 12-06-2016, 12:35 PM   #6
Rewards Points: 18
I ended up buying a new one and installed it last night.
COLDIRON, jmon and SHR Plumber like this.
Old 12-27-2016, 06:12 AM   #7
Great!!
markusriva125 is offline   Reply With Quote
Need input on indirect fired water heater install. A Squared HVAC 13 11-23-2013 04:42 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 05:00 AM
