Water Heater Leak? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-29-2016, 04:28 PM   #1
Rewards Points: 28
Water heater leak?
How do I diagnose water on floor around water heater? Came all of a sudden and I don't see any active leaks or drip spots
djc225 is offline   Reply With Quote
Old 09-29-2016, 04:42 PM   #2
Rewards Points: 18,784
Re: Water heater leak?
Looks like your relief valve may have opened up.
A few reasons why it can happen.
Temp. set to high.
Pressure surge if there's no pressure tank installed.
Valve defective.
Old 09-29-2016, 04:48 PM   #3
Rewards Points: 28
Interesting. I don't see any drips though from the overflow tube. Have an electronic thermostat on it and temp is actually set down pretty low
Old 09-29-2016, 04:49 PM   #4
Rewards Points: 28
So the question is, if it's not getting too hot why would there be a pressure surge?
Could it be anything besides the valve?
Old 09-29-2016, 06:50 PM   #5
Rewards Points: 1,856
Open up the burner door and look inside for water. If you got any water inside time to purchase a new tank. When you do this also replace the expansion tank .
Old 09-29-2016, 07:16 PM   #6
Rewards Points: 3,282
Regardless of the temperature setting (if not in vacation mode or off), it is possible to trip the temperature/pressure relief valve when the next tankful of water is heated. Tripping is more likely if there is no expansion tank and your house has a check valve or pressure regulator where the water supply first enters. You might have gotten away without tripping if there were pockets of air in the plumbing.
But I am going to guess that most likely the water heater has sprung a leak.
(You could put a cup or board under the re;ief valve downpipe to catch or divert any water coming out of that and better narrow down on the cause.)
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
Old 09-30-2016, 09:56 PM   #7
hkstroud's Avatar
Rewards Points: 6,684
I agree put a bucket under the T&P pipe. Wait and see what happens. Suspect that it is the T&P releasing. That too much water for it to be a leak and you not be able to see it.
hkstroud is offline   Reply With Quote
Old 10-02-2016, 10:18 AM   #8
Rewards Points: 80
Had your been AC is off? If it is, then for sure it's the tank or relief.
Cheers!
supers05 is offline   Reply With Quote
The Following User Says Thank You to supers05 For This Useful Post:
jmon (10-02-2016)
Need input on indirect fired water heater install. A Squared HVAC 13 11-23-2013 04:42 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 05:00 AM
