Water Heater Install Guidance? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-04-2016, 09:57 AM   #16
Rewards Points: 117
These were the parts listed on the detail.
Never done a drip leg before. I've only changed an HVAC gas valve last season.
Dornier is offline   Reply With Quote
Old 03-04-2016, 10:08 AM   #17
SHEPLMBR's Avatar
Rewards Points: 178
List looks about right.
SHEPLMBR is offline   Reply With Quote
Old 03-07-2016, 07:27 AM   #18
Rewards Points: 117
Is there a difference in construction between a 6 or 10 yr? Or, are you paying for the warranty that way?
I'll look at the drip leg.
Old 03-07-2016, 08:07 AM   #19
Rewards Points: 3,220
Not really. Higher end models probably are. Idk. Usually just an additional or longer anode rod adds to the warantee. Just my opinion.
jmon is offline   Reply With Quote
Old 03-07-2016, 08:08 AM   #20
SHEPLMBR's Avatar
Rewards Points: 178
Depends on the manufacturer. Some send a premium anode rod. Some it's just extra paperwork you have to register. Best to check with where you are buying it from or maybe the manufactuers website.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Strange plumbing to my elec water heater > photos Flt_Simulation Plumbing 17 05-13-2014 04:52 PM
Best practices for Water Heater install? simanco Plumbing 4 08-22-2012 11:36 PM
Water Heater Install - Water dripped into base sleewok Plumbing 7 07-06-2012 08:39 AM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
