Water Heater Draining Blue Crystals - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-14-2015, 06:41 PM   #1
Rewards Points: 352
Water heater draining blue crystals
Today I drained my moms water heater and it took several attempts to try and drain the water. The faucet was clogged with sentiment. After it finally started going, it was draining blue water with white crystal chunks. Wondering if this is normal or if I should be concerned with a potential problem.
drew53813 is offline   Reply With Quote
Old 12-14-2015, 06:57 PM   #2
Rewards Points: 3,282
I think it is hard to say for now whether this is a normal amount of solid material accumulating for a very long time versus some abnormality that caused a large buildup.
I trust that after not too long the water ran clear.
If you drain a small amount of water every 6 months the water should run clear after about a half gallon and you should not have the valve at the bottom of the tank clog up.
If you turn off the water supply and drain any significant amount of water then you need to shut down the water heater heat first. Then turn on the water and wait for water to gush from an open faucet upstairs for a minute before turning the water heater back on.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
Old 12-14-2015, 08:02 PM   #3
Rewards Points: 6,652
Does she have a Water Softener?
Old 12-14-2015, 08:08 PM   #4
Rewards Points: 18,790
That was my first thought to Gregzoll, beads from a softener, and that would be an issue.
Flushing out a water heater does not involve shutting off the water or the heater.
Just open up the valve on the bottom of the heater for about 10 min.
Turning off hot water to fix 1/2 inch CPVC pipe in crawl space steve3847 Plumbing 21 12-20-2012 01:53 AM
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 09:17 AM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 02:35 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
