Water Heater Corrosion - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2015, 08:07 PM   #1
Water heater corrosion
3 year old State gas heater shows extensive corrosion on output side only.
House uses copper only. Anyone ever seen this?
bhawleyusa is offline   Reply With Quote
Old 02-11-2015, 08:52 PM   #2
Rewards Points: 286
I had that happen when my anode rod was gone. Looking at the green stains, there might be a slow leak or condensation is forming on the hot pipe.
Dan
djlandkpl is offline   Reply With Quote
Old 02-11-2015, 10:14 PM   #3
Rewards Points: 3,496
I've seen it, usually on older hwh's though. Recommend replacing the nipple/union on the corrosive side in the near future. Hot side looks good. Just a suggestion.
I believe it's the cold water inlet which contains the dip tube as well. As mentioned, the anode rod could be bad. Good time to replace all three and be done with it. About 40-50 dollars in parts.
Just curious, are you on well or city? Hard water, water softener?
Others will be along with more suggestions.
jmon is online now   Reply With Quote
Old 02-12-2015, 05:35 AM   #4
Bob Sanders's Avatar
Rewards Points: 2,536
That green staining is the flux left behind after the joint was soldered. Clearly the joints were not properly wiped after they were done. The hot water side required more flux because of the T just above the union. I would hazard to guess excess flux dribbled down onto the (dielectric) union effectively shorting it, which is why you're seeing excess corrosion.
Replace it and wipe the pipe down.
Bob Sanders is offline   Reply With Quote
The Following User Says Thank You to Bob Sanders For This Useful Post:
jmon (02-12-2015)
Old 02-12-2015, 05:45 AM   #5
City water, little calcium buildup on fixtures suggest not hard water, no softner. Corrosion is on hot side.
The Following User Says Thank You to bhawleyusa For This Useful Post:
jmon (02-12-2015)
Old 02-12-2015, 05:46 AM   #6
Will replace union and clean pipes. Thanks.
jmon (02-12-2015)
Old 02-12-2015, 05:35 PM   #7
Rewards Points: 1,952
Perhaps try a dielectric nipple they seem to last longer.
Old 02-12-2015, 06:04 PM   #8
PoleCat's Avatar
Rewards Points: 1,658
Need a dielectric union also.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 02-12-2015, 06:59 PM   #9
No you don't
He only needs a dielectric nipple and a copper fip adaptor.
The electrolysis is caused by the water the nipple is lined and stainless steel. That type of steel does not have a problem with copper.
Old 02-12-2015, 07:12 PM   #10
Dielectric unions are garbage and only work 50% of the time (as clearly noted in your pic). I prefer using flex lines. There is a larger gap between the unlike metal surfaces and "shoring" is less likely to occur. Of course that would mean some pipe work adjustment to get flex lines in, in your case so it's probably not feasible. But next time you change the tank.....
Water heater issues?!? NJdan Plumbing 1 06-04-2015 07:42 PM
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
