Water Heater Connector - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2016, 05:26 PM   #1
Rewards Points: 1,180
Water heater connector
Pic of my old and new water heater. Was trying to match the adapter coming of the old threaded water nipples on top. The one I temp screwed onto my new water heater is what I bought....it's a female adapter. Does it look right? I was concerned because there's are more threads on the nipple than the adapter. Thanks.
Water heater connector-image-609134701.jpg   Water heater connector-image-466311067.jpg
Mstrlucky74 is online now   Reply With Quote
Old 02-13-2016, 05:30 PM   #2
Rewards Points: 582
there are always more threads than on an adapter like you have there..just make sure you don't over heat when you are soldering and apply pipe dope and or teflon tape to the threads before you tighten up the adapter...in fact presolder the pipe in the adapter before you install adapter to heater then you for sure won't over heat it...
The Following User Says Thank You to ben's plumbing For This Useful Post:
JERRYMAC (02-13-2016)
Old 02-13-2016, 05:38 PM   #3
WhatRnsdownhill's Avatar
Rewards Points: 2,220
dont forget a new ball valve on the cold water feed..
WhatRnsdownhill is offline   Reply With Quote
The Following 2 Users Say Thank You to WhatRnsdownhill For This Useful Post:
ben's plumbing (02-13-2016), JERRYMAC (02-13-2016)
Old 02-13-2016, 06:40 PM   #4
Sh$&.. I need that?? Ok.
So if I cut the pipe on both side of the ball valve won't water come pouring out because water is coming up to ball valve. Guess water has to be shut off further down the line.?? Thx
Old 02-13-2016, 06:41 PM   #5
Rewards Points: 18,960
It's a tapered thread, there's always threads left exposed.
Always best to use Teflon pipe dope not tape.
Old 02-13-2016, 08:12 PM   #6
water main.....shutoff..
Old 02-13-2016, 09:23 PM   #7
Rewards Points: 5,348
Put unions on both sides.
Ron
B. Franklin 1759
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
