Water Heater - Best Flexible Connectors - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-11-2016, 02:22 PM   #1
Rewards Points: 91
water heater - best flexible connectors
Guys,
I'm about to install a new water heater - gas, installed on home exterior (SoCal). I've done this twice before, and always used the flexible copper connections, and never had an issue with them.
My existing WH has flexible copper connections, they haven't failed - but I'm thinking it's $20 well spent to replace them?
Anyhow, I went online to look for some replacement copper connections, and see now a lot of water heater 'kits' that come with the water and gas connectors, but that the water connectors in a lot of them are braided stainless steel - they sort of look like beefier versions of a washing machine supply line.
I obviously don't want any issues with the WH, and as I've spent over $600 on the unit itself I don't mind spending a few extra dollars to ensure I have the better connectors in place with lowest chance of failure.
I'm aware of 3 types, flex copper, flex stainless steel, and braided stainless steel - is there a consensus on which types of flexible connectors work best, or what to avoid etc.?
thanks!
Matt
mmhendrie is offline   Reply With Quote
Old 05-11-2016, 07:15 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 162
Re: water heater - best flexible connectors
To me it's like picking between a Ford, Chevy or Dodge....... I doubt the benefits of one would out weigh the other
Old 05-11-2016, 10:59 PM   #3
Rewards Points: 1,852
Only thing I would replace is the washers on the old ones. Copper are excellent connectors.
Tags
braided , connector , copper , stainless steel , water heater
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Water heater problems- thought I fixed the problem- what do I do next? brandall Plumbing 23 04-19-2013 05:44 PM
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 09:17 AM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
