Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-05-2017, 05:53 AM   #1
Rewards Points: 396
water Heater
had trouble with water heater yesterday, took a cold shower. turns out there was no power going to it. did some testing and i guess the breaker was bad, what cause the breaker to go bad ? anyway, since i didnt have a spare breaker available at home late last night i switched it for the one to the garage heater since we dont need that right now. now this morning the water is so hot it burns you, its never been that hot before. whats up with that i wonder ?
shirbon is offline   Reply With Quote
Old 05-05-2017, 09:54 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 32,008
Re: water Heater
The thermostat on the heater is bad?
One of the elements is shorted to ground? The stat only switches one hot and the other hot is heating to ground?
Old 05-05-2017, 12:09 PM   #3
Rewards Points: 396
Re: water Heater
how do i test all that ?
Old 05-05-2017, 02:19 PM   #4
Rewards Points: 1,952
Re: water Heater
IF the tank is old I would suggest replacing it. Check the serial number date code. No point it beating a dead fish. Or even a horse.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
