Water Hammer Arrestors With PEX? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2016, 06:00 AM   #1
Rewards Points: 310
Water Hammer Arrestors with PEX?
Hi Everyone,
I am redoing my supply lines in my house with a PEX whole house system. I will be using a manabloc manifold. All runs will be home runs to each fixture.
With PEX, is it recommended to use water hammer arrestors for the dishwasher, clothes washer, or ice maker?
Thanks,
Pat
patrickpresti is offline   Reply With Quote
Old 01-14-2016, 08:05 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,188
It can't hurt, but my understanding is that the PEX has a certain elasticity to it that negates much of the hammer issue and certainly the noise.
That being said, the noise is not the primary concern with water hammer.
Old 01-14-2016, 12:00 PM   #3
Rewards Points: 310
Thanks for the feedback. Would you put water hammer arrestors on any other fixtures other than the three I mentioned?
Thanks,
Pat
Old 01-14-2016, 04:36 PM   #4
Solenoid controlled valving is supposedly the larger issue with the hard on/off closures.
Old 01-15-2016, 04:56 PM   #5
Rewards Points: 1,848
Depends on your code your under. Under IPC as an inspector I am suppose to enforce the stricter regulation code being the stricter out weight manufacturer. That would mean you would install a hammer on washer machine hot and cold and dish washer. We do not install hammers on ice makers. But that is a local decision.
Ghostmaker is online now   Reply With Quote
Old 01-15-2016, 05:17 PM   #6
Rewards Points: 310
Gotcha ghost. I bought arrestors for the clothes washer, ice maker, and dish washer...
Old 01-15-2016, 05:23 PM   #7
Rewards Points: 310
New York follows IPC
Toilet water hammer noise no come only when hot water is running at sink why? daluu Plumbing 0 08-24-2014 11:41 PM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
Do water hammer arrestors go bad? Red Squirrel Plumbing 10 09-24-2012 07:11 AM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
