Water Hammer After Valve Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2018, 10:34 AM   #1
Rewards Points: 4
water hammer after valve replacement
I recently changed the valve cartridge in tub/shower
Now I get a sustained jack-hammer noise when the valve is in the warm position.
Full cold or full hot work fine no noise, just in the middle position.
I have shut off the main and opened all valves to drain, then refilled system. The Noise remains
urchin is offline   Reply With Quote
Old 02-01-2018, 12:02 PM   #2
Rewards Points: 781
Re: water hammer after valve replacement
Check to see if a washer is in the path of the flowing water. It will cause a violent vibration.
ct18 is offline   Reply With Quote
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Toilet water hammer noise no come only when hot water is running at sink why? daluu Plumbing 0 08-24-2014 11:41 PM
Hot Water Heater Problems Btabach Plumbing 7 05-21-2012 01:24 PM
Leaky ball valve at incoming water line Bipin1948 Plumbing 5 10-03-2011 05:21 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
