Water Hammer? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2018, 11:21 AM   #1
Rewards Points: 44
water hammer?
I've been in my house for 7 years and it was only a few months ago that I started hearing a "water hammer". House was built in 72, not sure what our water pressure is but it's pretty high. It happens at completely random times, sometimes in the middle of the night when everyone is sleeping. Sometimes it'll last just a few seconds and occasionally I swear it lasts minutes.
What could cause this to suddenly start happening? I've noticed that when it's happening, it triggers the relief valve on my hot water heater and it'll release a small stream of water the entire "event".
Doelman is offline   Reply With Quote
Old 02-20-2018, 09:55 AM   #2
Rewards Points: 18,976
Re: water hammer?
#1, City or well water?
#2. Is there a pressure reducing valve?
#3, Check the water pressure.
https://www.homedepot.com/p/Rain-Bir...-P2A/100575619
#4, Check the toilets for a leaking flapper, just add some red food coloring to the tank and see if it ends up in the bowl overnight.
Old 02-20-2018, 12:59 PM   #3
Rewards Points: 3,454
Re: water hammer?
Please answer Joe's questions so we may better help you.
First, find out ur incoming water pressure. Check at any hose bib like garden or washer.
Is there an expansion tank on the water heater?
If there is a pressure reducing valve it may need servicing, adjusting or replacement. If ur water pressure is over 80 psi, and you don't have one, I would recommend installing one. Just a suggestion.
Normal water pressure is around 55-65 psi., and that's what ur expansion tank on ur water heater should be set to as well.
jmon is offline   Reply With Quote
Water hammer returns in a few days tearitup Plumbing 11 07-11-2015 08:30 PM
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Water hammer, expansion tank? bluefoxicy Plumbing 1 12-12-2012 05:48 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
