Water Filter Removal - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-02-2016, 03:19 PM   #1
Rewards Points: 141
Water filter removal
Hi...
I have Cuno water filter and need to replace the filter. I have been trying for many weeks on and off to get the housing off. It is an AP801 with the blue housing.
I have tried hitting it and the wrench itself wit a rubber mallet. I have not tried heating it yet with a hair dryer but probably is my next step.
Any suggestions on how to get this off?
whoppr is offline   Reply With Quote
Old 10-02-2016, 03:54 PM   #2
Rewards Points: 3,220
Re: Water filter removal
Yea you can try the hair dryer.
Another option, Get another plastic wrench use the two together with added leverage like a piece of 2in plastic pipe. Turn clockwise.
Or try the 10 and 2 position with your plastic wrenches and use a rocking motion going in both directions to try and break it free. Once you do get it removed use some silicon grease on the threads and o ring so next time this wont happen. Just a suggestion.
jmon is offline   Reply With Quote
Old 10-02-2016, 06:05 PM   #3
Rewards Points: 260
Have you pressed the vent to release the water pressure? Mine comes off easier when there's no water pressure in the filter.
Dan
djlandkpl is offline   Reply With Quote
Need help with whole house filter for well water CreepyOldGuy Plumbing 0 07-10-2016 09:58 AM
Hot water cross over mystery maroonw Plumbing 4 04-29-2016 05:14 AM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
Water Quality - Filter / Softener needed? fackert61 Plumbing 3 06-30-2012 05:09 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
