Water Filter Purchase - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-12-2015, 03:13 PM   #1
Water filter purchase
Hi,
I find myself changing our whole house filter 5 micron- every 2 months or less. If I don't the water pressure really decreases. When taking out the filter , it us orange and sludge - like.
We also have a reverse osmosis system under our kitchen sink it has 2 charcoal and 1 sediment 5 micron that I change every 4 months.
Anyways, anyone know of any good places online to buy from in bulk?
I just Baught 2 sediment filters from home depot for 10$.
chillz911 is offline   Reply With Quote
Old 11-12-2015, 04:03 PM   #2
This is the filter system I have
https://www.homedepot.ca/en/home/p.w...1.html?redir=s
Old 11-12-2015, 04:30 PM   #3
Rewards Points: 1,952
https://www.buydirectwaterfilters.co...ediment-filter
$3.80 a piece $50.00 or more on order free shipping USA
Old 11-12-2015, 05:49 PM   #4
I know there are a lot of experienced plumbers and posters who ewal with well small water works.
Can anyone suggest another filter system of reasonable value keeping in mind the frequency of me having to change filters..... do they make reusable filters? Mine end up with an orange sludge and aren't reusable
Old 11-12-2015, 05:57 PM   #5
ZZZZZ's Avatar
Rewards Points: 2,918
A lot of orange sludge isn't "normal" (for most areas of the country). Are you on city water or well water? Have you had the water tested?
ZZZZZ is online now   Reply With Quote
Old 11-12-2015, 06:03 PM   #6
And something that won't compromise pressure
Old 11-12-2015, 07:50 PM   #7
Well water......it's only after 2 months
Old 11-13-2015, 11:17 AM   #8
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
Water quality?
what size micron are you using?
size of filter?
2x10 or 4x10?
number of people in the house?
Akpsdvan is offline   Reply With Quote
Old 11-13-2015, 11:51 AM   #9
We are 4 people 2 adults and two toddlers
We are using 5 micron single filter 10 inch in size
Old 11-13-2015, 12:19 PM   #10
Water Treatment
Akpsdvan's Avatar
2" or 4" ?
Water Quality?
on average you most likely using about 180 gallons per day +/-
Old 11-13-2015, 01:06 PM   #11
Results were taken from samples in 2014
Hardness
0 grains after softener,
28 grains before
Iron
0.15 mg/l after softener,
1.8 mg/l before
Sulphur
No sulphur smell seeping through (rotten eggs)
PH
7.6
Total Dissolved Solids (TDS)
750 ppm after softener,
700 ppm before softener
Old 11-13-2015, 01:10 PM   #12
2" filter
Old 11-13-2015, 01:45 PM   #13
Water Treatment
Akpsdvan's Avatar
Have you tried it with out the filter?
If the filter was not in place would the softener still work?
Comp hardness at 36???
Raw 1.8
After softener .15
And what is it between the filter and the softener?
Old 11-13-2015, 02:20 PM   #14
No I haven't. ...the softener would still work I am sure.
Old 11-13-2015, 02:23 PM   #15
Raw 1.8
After softener .15
What do you suggest.... what do you think of the test results?
My hot water recirculation system is a disaster Michael Neill Plumbing 29 08-30-2019 06:15 PM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
Upgrading water supply plumbing...where to locate filter? Jim S. Plumbing 3 02-06-2009 11:13 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
