Water Doesn't Flow After Sprayer Used - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-18-2015, 11:27 AM   #1
Rewards Points: 6
Water doesn't flow after sprayer used
My kitchen faucet does not flow sometimes after using the sprayer. Sometimes it's fine and other times I can turn the hot and cold on and nothing comes out but the sprayer still works. It can be only a few seconds hesitation but sometimes it lasts for a couple minutes. I live in south Florida and the water here is very hard, if that has anything to do with it.
It doesn't happen every time but it's been getting a little more frequent since it began about a year ago.
The faucet is about 5 years old and is just a basic two handle model. I'm hoping it's a simple replacement needed.
Any help is greatly appreciated. Thanks.
jburd641 is offline   Reply With Quote
Old 10-18-2015, 01:10 PM   #2
Rewards Points: 1,938
You need to replace the needle valve to the sprayer. It's getting stuck.
Contact you faucet manufacture if it's a name brand.
Old 10-18-2015, 01:19 PM   #3
Rewards Points: 6
I'm curious, if I replace the faucet with one with a built in sprayer, will that solve the problem? I was wanting to upgrade anyway.
Thanks for your help.
Old 10-18-2015, 02:31 PM   #4
If you replace the entire faucet yes.
Old 10-18-2015, 04:26 PM   #5
Rewards Points: 6
Thanks!
Low water flow, new PRV, 90psi static GEAF Plumbing 5 05-31-2013 11:56 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Water flow & pressure problems DHughes54 Plumbing 3 04-18-2012 09:09 PM
Hot Water Flow kcirtap23 Plumbing 1 02-10-2012 04:11 PM
