Water Damage? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-27-2015, 11:45 AM   #1
Rewards Points: 8
Water Damage?
Does this look like water damage?
jennawaye is offline   Reply With Quote
Old 05-27-2015, 12:05 PM   #2
Rewards Points: 3,418
It's possible, hard to tell from the pic. Sure it's not just a stain.
jmon is offline   Reply With Quote
Old 05-27-2015, 12:06 PM   #3
Rewards Points: 8
hmmm
it goes away over time when the shower is not being used.
Old 05-27-2015, 12:07 PM   #4
Rewards Points: 8
what would cause a stain like that? also the size is slightly different in the two pictures, hard to tell I know lol
Old 05-27-2015, 12:26 PM   #5
Grout could be starting to break down in that area. Idk. When it dries out the water stain goes away. Just a Thought. Any staining on ceilings below or are you on a slab?
Others will be along with more advice/suggestions.
Old 05-27-2015, 05:04 PM   #6
Special User
Rewards Points: 1,230
Looks to me like the glazing is gone from the tile, possibly from chemical exposure (somebody pour something nasty down that drain at some point?).
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
The Following User Says Thank You to tylernt For This Useful Post:
jmon (05-27-2015)
Old 05-27-2015, 05:25 PM   #7
Property Mgt/Maint
Rewards Points: 8,202
heavy duty drain cleaner is my first thought
[political signature removed]
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
tylernt (05-27-2015)
Mysterious Yellow How Water in Tub only heyjoe91 Plumbing 11 10-22-2013 03:23 PM
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
Water damage. How bad can it be? alexin General DIY Discussions 3 08-23-2010 01:53 PM
