Water Backup In Basement. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2015, 05:20 PM   #1
Rewards Points: 148
Water backup in basement.
I have a 2 family house. There is water coming out of the drain in the basement/garage which is about 10 feet away from the driveway (inside the garage).
This only happens when the 1st floor bathroom is being used. (BUT no water backup in the bathroom at all). What could this be?
nj2012 is offline   Reply With Quote
Old 01-21-2015, 05:22 PM   #2
Rewards Points: 582
sewer line is clogged
The Following User Says Thank You to ben's plumbing For This Useful Post:
nj2012 (01-21-2015)
Old 01-21-2015, 05:24 PM   #3
Rewards Points: 148
I see. but what I'm wondering is why the 1st floor bathroom and not the 2nd or 3rd floor?
I can rent a 50' 1/2" snake from homedepot. is it easy to use? Do I just put it in the drain and guide it in there or how does that work?
Can I use any chemical to clear it?
Old 01-21-2015, 05:32 PM   #4
Rewards Points: 582
I don't use chemicals at all..never did .....you could rent a snake like you said..but its not as easy as some may think and it can be dangerous as well ...you insert into drain turn on power and push into drain feeling the cable going into pipe and around bends is the tricky part...also to know when to push harder or to stop and back up some machine don't bind up and twist cable....
Old 01-21-2015, 07:25 PM   #5
Retired Moderator
Rewards Points: 7,174
It will be difficult to get a snake into a floor drain because of the P-trap---perhaps impossible--
Find a clean out port that will get you into the clogged line---
I always call a plumber for rodding the main lines----I find the job to be messy and a bit dangerous---so I let a pro handle that one----
Old 01-21-2015, 08:27 PM   #6
Rewards Points: 148
Mike I wish I would have read your comment 2 hours earlier. I rented a snake and sat in the basement for 2 hours trying to get it in. Calling plumber first thing in the morning.
Old 01-21-2015, 08:33 PM   #7
Rewards Points: 582
is there another place you can go in at ..picture may help us direct you..fyi we put snakes thru traps all the time you really to push while is turning...
Old 01-21-2015, 08:42 PM   #8
Rewards Points: 148
I actually now see a long white tube attached to the sewer (big rusted brown pipe) that white tube just ends off and doesn't go anywhere. Maybe I should feed the snake through there?
The Following User Says Thank You to nj2012 For This Useful Post:
oh'mike (01-21-2015)
Old 01-21-2015, 08:45 PM   #9
Rewards Points: 582
picture will help..i
Old 01-21-2015, 09:22 PM   #10
Rewards Points: 148
Here is the image
Old 01-21-2015, 09:29 PM   #11
Retired Moderator
Yep--see if there is a cap on that--should unscrew---
Old 01-21-2015, 09:30 PM   #12
Rewards Points: 148
Yeah I see that. so I should snake it from there? I just dont want to mess up more things.
Old 01-21-2015, 09:50 PM   #13
Rewards Points: 3,430
Looks like you have a Y on that cast iron pipe with a plug that can be removed as well for snaking. Tuff spot for snaking. Can't really tell, could be the pic. Probably easier to remove the cap on pvc and go in there as suggested. Wait for Ben's reply, he'll know.
jmon is offline   Reply With Quote
Old 01-21-2015, 09:53 PM   #14
Rewards Points: 148
Yes it's a y pipe where is the cover you are talking about?
Old 01-21-2015, 09:53 PM   #15
Rewards Points: 148
Plug I mean. Where is that plug?
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
Water Leakage Under Basement Window Well Slomarmoreno Plumbing 2 09-18-2012 05:40 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
