Washing Machine Valves - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-07-2015, 02:02 PM   #1
Rewards Points: 4
washing machine valves
Greetings.
Can anyone identify these valves? I cannot estimate the age as laundry room position was moved in this house. I also do not know if they are sweat connection vs. compression fitting.
Packing under cold water valve bonnet nut leaks under pressure. I keep these valves off when the washing machine is not in use.
Thanks kindly.
washing machine valves-wp_20150928_001.jpg   washing machine valves-wp_20150928_002.jpg   washing machine valves-wp_20150928_003.jpg   washing machine valves-wp_20151002_001.jpg   washing machine valves-wp_20151002_002.jpg
ks120196 is offline   Reply With Quote
Old 10-07-2015, 03:07 PM   #2
Rewards Points: 1,932
Without opening the wall your guess is as good as mine could be a sweat connection or threaded. Have you tried using new packing under the packing nut yet?
http://www.homedepot.com/p/DANCO-5-3...0074/100123660
Ghostmaker is online now   Reply With Quote
Old 10-07-2015, 03:16 PM   #3
Rewards Points: 6,354
Check with a plumbing supply or possibly ACE Hardware and see if they have a new packing stem seal.
Old 10-07-2015, 05:24 PM   #4
Rewards Points: 582
the constant opening and closing of the valve have worn out the packing...if the washer is in the basement open the valve and snug packing if it does not leak leave it open..if it continues to leak as mentioned try to replace packing ..then leave valves open ...turning them on and off really serves no major purpose...
Replacing Washing Machine Water Shutoff Valve aimforthenail Plumbing 11 10-04-2013 09:41 AM
Washing machine discharge hose Deck Plumbing 7 01-14-2012 08:15 PM
Vinegar in the Washing machine wraiththe Plumbing 6 01-12-2012 10:51 PM
Strainer in washing machine discharge line? bwendholt Plumbing 7 12-04-2011 06:01 AM
washing machine hookup problem poppito Plumbing 5 03-11-2010 02:17 PM
