Washing Machine Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree5Likes
  • 1 Post By daveb1
  • 1 Post By Yodaman
  • 2 Post By Nealtw
  • 1 Post By HoneyBee Hiker
Old 05-30-2019, 09:33 AM   #1
Rewards Points: 6
Hello,
We just moved into a new house. It was built in 1960. We were testing out the washer in the basement and it seems like the drain hose is either not set up correctly or there is a clog in the pipes. When the washer switched cycles to drain water started spraying and gushing everywhere. So I stopped the washer. We bought some snake drain unclogging tools and didn't find anything. But the snake tools were able to reach the whole way through the S bend pipe. Need some advice and some help with this.
HoneyBee Hiker is offline   Reply With Quote
Old 05-30-2019, 10:47 AM   #2
Rewards Points: 150
Re: Washing Machine Plumbing
Can you determine what size the drain pipe is? If it's too small it won't be able to handle the quantity of water that the machine pumps out. I think washer drains require 2" but stand to be corrected.
HoneyBee Hiker likes this.
daveb1 is online now   Reply With Quote
Old 05-30-2019, 11:17 AM   #3
Property Mgt/Maint
Rewards Points: 8,066
Can you post a pic of the trap and stand pipe? It sounds like the pipe drains, just not fast enough to handle the amount of water. Could also be the stand pipe is too short or the drain size too small. Should be 2" for current code, but many have been set up with 1 1/2 and have worked fine for decades.
[political signature removed]
Yodaman is online now   Reply With Quote
Old 05-30-2019, 11:28 AM   #4
Rewards Points: 6
Interesting thought. I will take a look at the hose this afternoon and post a picture.
Old 05-30-2019, 03:08 PM   #5
Rewards Points: 6
The stand pile opening is 1 1/2 in and the washing machine draine hose is 1in.
Old 05-30-2019, 04:17 PM   #6
retired framer
Rewards Points: 9,466
One option is to change it to a sink that can handle that much water.
daveb1 and huesmann like this.
Do not use flat bottom gables with scissor trusses.
Old 05-31-2019, 06:51 AM   #7
Rewards Points: 6
Good suggestion about the sink! I didn't think of that. Thank you I"m hoping to hear back from a few plumbers that I called.
Nealtw likes this.
Old 05-31-2019, 07:17 AM   #8
Property Mgt/Maint
What is the length of the stand pipe? If too short water might splash out. Should be about 2'.
On one occasion years ago I would intermittently would have a similar problem. My solution at the time was to fit the stand pipe with a threaded adapter, then a barbed fitting adapter. The hose would then slide over and be secured with a hose clamp.
I don't believe this creates a code issue, one of the master plumbers might chime in and clarify.
Old 05-31-2019, 07:44 AM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 402
When you do that you eliminate the air gap and a waste waterr can back up into the washer under certain conditions.
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 06-01-2019, 01:13 PM   #10
Rewards Points: 1,714
Is your drain filling and squirting out water. If so you may have a blockage down the line.
Old 06-01-2019, 02:10 PM   #11
Hammered Thumb
Rewards Points: 1,372
It is common in that era of house that the 1 1/2" pipes, if buried and are a distance from the main stack, are filled with some solidified gunk, that running a snake will not dislodge or you may not even feel hindrance on it going in. The pipes could even be galvanized which is worse.
Have come across it many times, so when re-doing plumbing is not prudent, a laundry tub will need to be used to let the washer drain at its pace.
3onthetree is offline   Reply With Quote
Old 06-01-2019, 04:38 PM   #12
hkstroud's Avatar
Rewards Points: 6,518
The drain water from a clothes washer carries a lot of lint with it. That can settle in and stop up the trap. If you got your snake to go through the trap it must be a small one. That lint will be soft and your snake can simply go through it.
Snake again. Run your snake in through the trap. Then fill up the stand pipe with water and work the snake through the trap several times. When the water has drain away, stick you hose in stand pipe and let the water wash away the lint as you work the snake back and forth through the trap.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 06-03-2019, 08:37 AM   #13
Rewards Points: 2,882
Also, get yourself a lint trap for your washing machine hose!
huesmann is offline   Reply With Quote
Old 06-04-2019, 10:04 AM   #14
Rewards Points: 3,052
Many modern washing machines require a 2 inch drain pipe even though their hoses may be just 1 inch. For those machines a 1-1/2 inch drain pipe, even perfectly clear, might never work.
You should not seal the drain hose into the drain pipe. This might overload the washing machine internal pump and shorten its life.
Either replace the washing machine drain pipe and trap (also called a standpipe) with a 2 inch one together with other drain piping as needed to meet code, or install/use a laundry tub (does not need faucets of its own)..
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
Tags
clog , laundry , plumbing , s bend pipe , washing machine
