Washing Machine Drain Pipe Height? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-07-2016, 11:20 AM   #1
Rewards Points: 261
Washing machine drain pipe height?
Thanks in advance.
We are remodeling the laundry room which will include built ins over the washer and dryer as well as a countertop.
Currently the hot/cold/drain are all about 48 inches from the floor.
The top of the washer and dryer 40 inches from the floor.
My question is around the drainpipe, is there a minimum it can be from the top of the pipe (where you put the washer drain hose) to the floor?
I have read it is a minimum of 18" above the water line in the trap itself.
We are trying to lower all the connections so they are under the countertop in order to tile the wall above it.
The hot and cold are no problem, it is the trap/drain pipe length I want to make sure is right.
Thank you again
beachfront71 is offline   Reply With Quote
Old 03-07-2016, 11:25 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,348
You will have to open the wall either way. You should be able to just move the trap down correspondingly I would think.
Old 03-07-2016, 11:36 AM   #3
Rewards Points: 261
Thanks, I get what you are saying .. but ..
is 18" minimum above the trap the code I need to be working off of?
Old 03-07-2016, 11:51 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 166
*UPC code states the trap is a minimum 6" above the floor.
Minimum riser length = 18"
Maximum riser length = 30"
Riser length is from the wier of the trap, to the receptacle opening.
Old 03-07-2016, 06:14 PM   #5
Rewards Points: 261
Thanks and new problem. There is no trap, it runs right through the floor of the wall to under the house where it connects with the main in a crawlspace which heads into the ground.
Do I need a trap? House is 25 yrs old, always been this way and there has never been a smell.
If I remember correctly, if you followed the main line from the ground up to the house, this is the last drain that is connected to it, meaning it is at the end/termination of the main line so would it be protected by the other traps and vents ahead of it (shower, tub, etc)?
Old 03-07-2016, 06:25 PM   #6
Plumber
Rewards Points: 166
Possibly. Or your trap is right below the floor? Most times, untrapped drains will stink
Old 03-09-2016, 12:56 PM   #7
Rewards Points: 767
That needs to be trapped.
ct18 is offline   Reply With Quote
Washing machine drain pipe replacement? mbrockman5 Plumbing 15 08-28-2015 04:09 PM
how to drain (pump) washing machine upwards? debiasio Plumbing 11 11-19-2013 07:52 PM
washing machine drain issues lost_punk Plumbing 2 06-19-2012 10:18 AM
Washing Machine Drain Pipe overflows evol200 Plumbing 3 01-27-2011 12:41 PM
Drain Pipe to Washing Machine houston81 Plumbing 10 07-07-2010 06:39 PM
