Washing Machine Drain, Line Need An Air Vent? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-09-2016, 03:44 AM   #1
Rewards Points: 4
Washing Machine Drain, line need an air vent?
Our building engineer wants all non-venting washer dryer units to have the washer connected to the buildings main air duct.
The manufacturer says it isn't necessary. The machine has worked perfectly for 4 years with no drainage problems whatever.
Is an air intake necessary to the main building air duct or is any air put into the drain necessary?
Does a non-vented washer/dryer need an air vent in its drain?
Richard Higer is offline   Reply With Quote
Old 02-09-2016, 04:33 AM   #2
An old Tradesmen
Rewards Points: 9,248
Made this its own thread.
Old 02-09-2016, 05:23 AM   #3
Retired Moderator
Rewards Points: 7,174
Yes it does----and has for many years---how was this built without one,I wonder.
Old 02-09-2016, 07:59 AM   #4
dd57chevy's Avatar
Rewards Points: 2,948
I assume your "engineer" means sewer vent when he says it needs to be connected to the building's "main air duct" . I hope so , anyway .........
Depending on your buildings drain system's condition/design , the volume & force of a washing machine's drain cycle could cause problems if not vented .
dd57chevy is offline   Reply With Quote
Old 02-09-2016, 03:49 PM   #5
Rewards Points: 1,868
Not very clear post here...
The Following User Says Thank You to Ghostmaker For This Useful Post:
oh'mike (02-09-2016)
Old 02-09-2016, 04:17 PM   #6
Retired Moderator
Not enough coffee----
dd57chevy (02-09-2016)
Old 02-09-2016, 04:20 PM   #7
WhatRnsdownhill's Avatar
Rewards Points: 2,220
you have to clarify....do you mean the dryer exhaust needs to be vented outside, or a vent line on the washing machine drain?
WhatRnsdownhill is offline   Reply With Quote
Washing machine to main line Robv81 Plumbing 8 12-24-2013 09:09 PM
Hooking dishwasher up to Washing machine supply line Jbussiere Appliances 4 11-13-2012 06:32 PM
Vent line has goes UP, down, UP - can I drain lowest point? calphalon Plumbing 22 09-20-2012 09:06 PM
Washing machine drain line noise MikeKy55 Plumbing 2 12-03-2009 08:19 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
