Washing Machine Box's - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-07-2015, 09:58 PM   #1
Rewards Points: 1,102
washing machine box's
i am rebuilding my small laundry room. i need to have ALL of the plumbing in the wall. wall cavity can be open behind the machine. the issue = if i use a 3 5/8" wall box, how do i get the WM drain hose from inside the wall cavity into the box ?
Fix'n it is offline   Reply With Quote
Old 06-07-2015, 10:23 PM   #2
Retired Moderator
Rewards Points: 7,174
The washing machine drain/water line box is mounted to the studs---the washing machine hose is hooked into the hole from the outside---
perhaps I am confused--why would your machine hose be inside of the wall cavity?
Old 06-07-2015, 10:29 PM   #3
there is very little room in front of both machines. i'm talking every 1/2" counts.
i am thinking to not even use a box. i also need to place the suplies in the cavity. are there shut off's that can be screwed to a board ?
Old 06-07-2015, 10:50 PM   #4
something like this would be great, and my wife could work it.
http://www.askmehelpdesk.com/attachm...alve.jpg?stc=1
Old 06-08-2015, 05:09 AM   #5
Retired Moderator
Now I understand---take the box back---a 2" stand pipe and stud mounted shut off valves will do the job.
Washing machine question Underestimater Electrical 3 03-05-2015 09:46 AM
Problem with Candy Smart CTDF 1007 Washing Machine (European washing machine) PBEnglish Appliances 4 09-11-2012 12:07 PM
Can I turn off hot water to Washing Machine? okk Plumbing 12 08-10-2012 07:14 PM
Plumbing or Washing Machine Issue svaic00 Plumbing 4 08-06-2012 08:46 AM
