Washers On P-Trap - Need Help With Placement - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2018, 03:46 PM   #1
Rewards Points: 266
Washers on P-Trap - Need Help with Placement
I was wondering if someone could help with the placement of washers on the P-trap that I bought. It's a 400PVCK by Keeney. The instructions provided only show a washer being used on the tailpiece/trap connection, but the package includes 4 total. One appears to be a reducing washer, which I'm assuming I can use to make the connection to my 1 1/4" faucet. Do I need one at the PVC/adapter connection, or where the J Bend connect to the wall bend? Are those small bumps on the washers okay, or will they cause issues? Sorry if my terminology is a little off...I'm definitely a novice.
Washers on P-Trap - Need Help with Placement-img_0736.jpg   Washers on P-Trap - Need Help with Placement-img_0737.jpg
chris87 is offline   Reply With Quote
Old 01-03-2018, 04:01 PM   #2
Rewards Points: 311
Re: Washers on P-Trap - Need Help with Placement
Did you try going to their site? they might have a view of it
christoff is offline   Reply With Quote
Old 01-03-2018, 04:05 PM   #3
retired framer
Rewards Points: 15,424
Can you post a picture of the pipe where you intend to hook this up?
A plumber should be along shortly.
Old 01-03-2018, 04:19 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
Can I assume that is a 1.25" trap? You need a washer where the wall pipe comments to the trap adapter, reducing washer if it is a 1.5" trap adapter. You need a washer where the tail piece goes into the trap. No washer where the trap connects to the wall pipe.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 01-03-2018, 04:42 PM   #5
Rewards Points: 266
It's a 1 1/2" trap. I was planning to use a reducing washer where the tailpiece and j-bend connect.
Old 01-03-2018, 05:09 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
Correct.
Sent from my RCT6213W22 using Tapatalk
Old 01-03-2018, 06:13 PM   #7
ZTMAN's Avatar
Rewards Points: 628
And the reducing washer is the big/thick one in your pic. The washers are directional.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 01-05-2018, 01:01 PM   #8
Rewards Points: 266
Thank you for taking the time to help me. I connected everything, but I'm having trouble. I can't get the J bend and tailpiece to line up perfectly. In picture 1, you can see how it's on a slight angle. Not good, I know. They are just slightly off, and the tailpiece seems to be just a tad short. I think that's why there is a drip at the arm/j-bend connection. I tried using an extension tube (see second picture), but it doesn't fit properly. The collar in the center is causing issues. I'm wondering if I need a whole new tailpiece, or if I can trim the existing tailpiece from Moen, so that the extension fits.
Washers on P-Trap - Need Help with Placement-img_0738.jpg   Washers on P-Trap - Need Help with Placement-img_0741.jpg
Old 01-05-2018, 01:58 PM   #9
ZTMAN's Avatar
Rewards Points: 628
You can trim the tail piece.
Hold your extension next to what is in your second pic. Put the end of the tail piece extension next to the shoulder of the p trap. Mark the original tail piece at the shoulder of the tail piece extension. Cut the tail piece at that mark.
You will probably end up cutting off about three to five inches.
Based on the pic, you may need to put in a 22 1/2 elbow, if the tail piece does not align properly with the trap.
Old 01-05-2018, 08:21 PM   #10
hkstroud's Avatar
Rewards Points: 6,694
It is very hard to tell what is straight up looking at a photo. All depends on how you are holding the camera.
It appears that your problem is that the sink drain and the J bend are not in alignment. Now the sink drain will be absolutely vertical. That means that the J bend is out of alignment. The only thing that can push the J bend out of alignment is the trap arm, the part connected to the pipe coming out of the wall.
Disconnect the trap arm. Let your connection of the J bend to the sink drain correct it self.
Then try to reconnect the trap arm. I think you will find that the trap arm is to close the the sink drain to connect with out pushing the J bend over (back out of alignment with the sink drain pipe). Rotate the J bend counter clockwise slightly so that it takes distance horizontally.
To say it more succinctly. Disconnect the trap arm from the J bend. Push the arm back into the wall slightly. Turn the J bend counter clockwise slightly until it is in alignment with the trap arm. Pull the trap arm out until it meets the J bend (in its new position) and reconnect it.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Trap Placement sawmkw Plumbing 7 01-26-2015 06:43 AM
PVC trap adapter on galvanized trap? dougan Plumbing 2 10-05-2012 06:16 AM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 07:59 PM
Hose filter washers placement dougp23 Plumbing 3 12-23-2011 08:05 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
