Washer Dryer In Boiler Room - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-12-2015, 06:01 PM   #1
Rewards Points: 1,192
Washer dryer in boiler room
Have two hot water heaters and two boilers(legal apt) in my boiler room. It fairly large and was thinking about putting a small compact stackable washer dryer for my tenants. Can this be done? Is this a DYI? What are things to consider such as cesspool filling up quicker etc. ? They have there own panel so I would run the electric from that . Thanks a lot.
Mstrlucky74 is offline   Reply With Quote
Old 06-12-2015, 06:06 PM   #2
Rewards Points: 1,942
I would hope you had your septic sized by your local health department for two family use.
Old 06-12-2015, 06:12 PM   #3
Rewards Points: 18,976
My main concern would be how to run the drain.
Old 06-12-2015, 06:17 PM   #4
The washer drain?? Right out the window down the driveway
The Following User Says Thank You to Mstrlucky74 For This Useful Post:
supers05 (06-13-2015)
Old 06-12-2015, 07:33 PM   #5
Good way to get hit with a huge fine. Sure hope you where kidding.
Old 06-13-2015, 01:02 AM   #6
Rewards Points: 1,414
Yeah, that doesn't sounds like a practice they would like on Long Island.
Your local inspector probably has walk-in hours or an email address. I would ask him.
Tom738 is offline   Reply With Quote
The Following User Says Thank You to Tom738 For This Useful Post:
gregzoll (06-13-2015)
Old 06-13-2015, 07:19 AM   #7
I was kind of kidding. On the same ground level our washer machine is 2 room down and we have a PVC pipe that goes out the wall to a dry well. Maybe I can run a pipe out the window down along the house 10' and tie into that pipe!!??? Thx
Old 06-13-2015, 07:49 AM   #8
Rewards Points: 3,428
No, you may not.
Running the drain line outside is a separate independent topic from installing a washing machine in a boiler room.
Also as a very general principle it is not desirable to give rental tenants unrestricted access to the furnace and other utility equipment of the building.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
Old 06-13-2015, 01:19 PM   #9
EPA is going to love this guy. Sounds like a conversion to multifamily from single family.
Old 06-13-2015, 04:59 PM   #10
Retired Moderator
Rewards Points: 7,174
Separate water service and a boiler for each unit? Most likely legal.I would suspect--
--OP--post a picture of the available plumbing--drains and piping--
You may have an issue with the water lines---which unit will be paying for the water?
Old 06-13-2015, 05:37 PM   #11
Lol.....
Old 06-13-2015, 05:38 PM   #12
Originally Posted by oh'mike
Separate water service and a boiler for each unit? Most likely legal.I would suspect-- --OP--post a picture of the available plumbing--drains and piping-- You may have an issue with the water lines---which unit will be paying for the water?
Will do
Old 06-13-2015, 06:34 PM   #13
Just install a stand pipe from the washer to your floor drains and indirectly drain them. You can do that for washer under IPC, don't know about your area though.
You cannot send it out to the local environment untreated. But you can always look into a grey water holding system if you want to water your lawn.
Pipes to washer and dryer ran though attic vw06gti Plumbing 5 09-03-2013 01:21 PM
Water damage in laundry room re: clothes dryer outlet mcbutterpants Electrical 3 02-07-2011 09:33 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
question about cleaning a boiler room Piratehart General DIY Discussions 1 02-14-2006 12:58 PM
