Washer Drain - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 1 Post By chandler48
  • 2 Post By DR P
Old 01-23-2018, 05:00 PM   #1
Rewards Points: 4
Washer drain
My washer is in the basement that drains into a pipe thats above it. it looks kind of....cob jobbed? im not sure as im a first time home owner and dont really know much about plumbing at all. was just wondering if that is the proper way to do it and if theres any way to make it look "cleaner" with a valve/adapter/fitting of some sort? thanks in advance!
UpstateNYRookie is offline   Reply With Quote
Old 01-23-2018, 05:01 PM   #2
Rewards Points: 4
Re: Washer drain
Old 01-23-2018, 05:21 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,734
Re: Washer drain
Technically the washer will pump it that high, and you need a trap, which you have. Not the best drain, but the cards are dealt. I only question the method of securing the washer drain pipe to the drain pipe. Does it pop out or is all that tape necessary? You won't get any sewer gasses since you have a trap. It is possible the original owner had problems with it backing up when pumping, thus the cob tape.
While we are on the laundry subject, pull all that corrugated dryer pipe down and replace it with smooth bore solid pipe. The corrugated will catch a bunch of lint and it will fall to the bottom and cause an occlusion, making drying less effective and possibly a fire.
COLDIRON likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
UpstateNYRookie (01-23-2018)
Old 01-23-2018, 08:00 PM   #4
Rewards Points: 16
Re: Washer drain
As long as the washer can pump to that height (it should), it's unusual but OK. The drain pipe through the wall is what it is, external plumbing no doubt created when the house was built. The washer in the basement is an afterthought. If the washer has trouble emptying and pumping the water up to the drain pipe, you would need an auxiliary lift pump to help it along. They even make "up flush" toilers for use below grade like that. Saniflow makes a whole line of plumbing products designed for situations like that.
https://www.upflushtoilet.com/pages/faq-basement-toilet
Gary RV-Wizard is offline   Reply With Quote
Old 01-23-2018, 08:09 PM   #5
Peace be with you
DR P's Avatar
Rewards Points: 1,860
Re: Washer drain
standpipe for washer isn't long enough
allowing bubbles/suds etc to blowback
that's my guess why tape is there & that
double 90 direction change is not helping either
Peace
COLDIRON and Guap0_ like this.
DR P is offline   Reply With Quote
Old 01-24-2018, 07:02 AM   #6
Rewards Points: 2,074
Re: Washer drain
All good advice. Redo that drain line , get rid of 2 of them ells, make the straight piece longer.
Dryer vent . Remove that fire hazard slinky. Install galvanized pipe, Use duct tape or metal tape, no screws, Make sure the pipe joints are going with the flow of the exhaust right from the start out of the dryer. No trapping lint.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Condo drain in upper unit caused drain in lower unit to leak? dangre Plumbing 15 07-09-2016 08:45 AM
Need Help With Adding Sink Next To Washer, Which Overflows Kitchen Sink JustinRampage Plumbing 36 01-30-2016 10:26 AM
Condensate Drain Line Mystery FrogFan HVAC 5 09-24-2015 09:27 PM
Adding washer to basement with no way to vent drain pipe General Plumbing 6 12-26-2010 11:11 AM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 10:35 PM
