Want To Run A New Water Line For Icemaker, Can I Do It This Way? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2016, 11:46 PM   #1
Rewards Points: 2
Want to run a new water line for icemaker, can I do it this way?
I have a copper line that runs from a pipe by my water heater, up to a floor in my kitchen where it stops, it had a a connection on it which connected a water line to the fridge... I tried to replace it but kept getting a leak by the copper so what I want to do is get a long 6 or 8 foot braided ice maker line, eliminate the copper line completely, and just connect the braided line to the shutoff valve by the water heater , and run it directly to the fridge. My question is can I do it that way? Or does it have to be copper? It seems like when you buy a whole kit, they all have copper line... keep in mind my fridge is directly above the water heater, so a pretty short run . Here is some pics. Thanks for the help
Want to run a new water line for icemaker, can I do it this way?-img_3102_1476593126539.jpg   Want to run a new water line for icemaker, can I do it this way?-img_3103_1476593149777.png   Want to run a new water line for icemaker, can I do it this way?-img_3103_1476593181140.png
Mkr88x is offline   Reply With Quote
Old 10-16-2016, 05:17 AM   #2
Re: Want to run a new water line for icemaker, can I do it this way?
Yes u can use braided line.
jumpgood is offline   Reply With Quote
Old 10-16-2016, 06:44 AM   #3
Rewards Points: 8,351
Keep in mind that the braided line has a plastic line inside the braid. Needs to be kept away from the h20 chimney.
Yes it should work but probably is not to code. I think the cutoff needs to be near the Fridge.
Mine runs from the sink to the Fridge along the back inside of my cabinets and the delivery people declined to connect it for that reason, saying there were not allowed to connect unless I had a box with a cut off.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is online now   Reply With Quote
Old 10-16-2016, 07:45 AM   #4
Rewards Points: 5,666
I'm guessing your leak with the copper is at the fitting(s) because the ferrule hasn't been set to the tubing correctly. If you are to be a DIY'er you may as well learn how to do that now rather than later and save yourself money as well as aggravation.
Old 10-16-2016, 08:49 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 812
I would run flex copper up thru the floor, install a stop and then transition to the braided flex.
My electrical answers are based on 2017 NEC, you may have local amendments.
Water line running through garage drywall physdl Plumbing 6 07-09-2015 08:50 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Proper Water and Gas line bonding. John318 Electrical 5 11-16-2011 11:19 AM
Leaky ball valve at incoming water line Bipin1948 Plumbing 5 10-03-2011 05:21 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
