Very Little Water Coming From Sprinkler Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-29-2017, 02:17 PM   #1
Rewards Points: 44
Very little water coming from Sprinkler Pump
The sprinkler pump was turning on only for a few seconds and then shutting down and then would restart again for a few seconds... like it could not keep prime. I replaced the check valve and all piping north of it leading to the sprinkler pump. now it turns on and does not shut off but there is still almost no water.
I have tried filling it with a hose from the hose bib.
When I take the house bib off and fill the pump with water, I can see that the water is remaining it is not leaking out.
Was I supposed to fill the suction pipe going into the ground with water before installing the new check valve and piping north of the check valve?
sabai is offline   Reply With Quote
Old 04-29-2017, 07:40 PM   #2
Rewards Points: 3,452
Re: Very little water coming from Sprinkler Pump
Welcome to the forums sabai.
Click on the link for some basic troubleshooting advice. Read symptom 2 especially. The plumbers will be along shortly.
https://www.tractorsupply.com/know-h...roubleshooting
jmon is offline   Reply With Quote
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
well pressure switch NJ Lady Plumbing 32 12-16-2013 03:48 PM
Well water to sprinkler system questions C_J_GO Landscaping & Lawn Care 8 01-30-2013 09:34 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
