Vertical Wet Venting? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-28-2015, 03:53 PM   #1
Rewards Points: 327
Vertical wet venting?
I'm about to frame/insulate a basement wall, which has a 1 1/2 inch copper drain line nearly flush to the block wall. This drain runs down from the laundry room on the main floor, and is the outflow of the washer standpipe.
A few feet above the basement floor, the copper drain line has a tee, which meets the trap arm of a sink in what once was a bathroom.
I believe this is a vertical wet vent--is that correct?
And if so, the tee should be removed, and nothing in the basement should drain into it?
I don't care really about the basement sink, I just don't want to have to go back and fix the drywall and framing later.
A laundry tub might be nice there one day, but if this really in non-compliant with code, I can deal with it.
Were vertical wet vents allowed back in the day (1951)?
dave11 is offline   Reply With Quote
Old 05-28-2015, 04:13 PM   #2
Rewards Points: 1,932
No, sounds like some one hacked a laundry room on the first floor illegally. No wet vent between floors. Ps. if your being inspected your drain is undersized for the washer and you should have a vent from the washer out the roof or tied into a vent that go's out the roof.
Old 05-28-2015, 05:02 PM   #3
Rewards Points: 327
All the drain lines appear to be original, nothing was added. 1.5 inch copper with cast copper fittings all around, all soldered the same way.
There is a vent in the laundry room to roof.
Either this wet vent was allowed in 1951, or it was never inspected.
Old 05-28-2015, 05:47 PM   #4
Rewards Points: 582
get us a picture if you can....pittsburgh has always had strict plumbing code for as long as i can remember ..and they enforced it....or fines we handed out big time....even in the 50s & 60s they were tough...
Old 05-28-2015, 06:07 PM   #5
Maybe he's in Philadelphia.. They do weird things.
Old 05-28-2015, 07:20 PM   #6
Rewards Points: 582
his location says pittsburgh
Ridge Cap Venting Issues - Poor Ventilation?? askeyb Roofing/Siding 16 03-29-2016 04:05 PM
A different kind of question - possible to go from vertical to horizontal venting? Lyzic HVAC 8 03-22-2015 07:03 PM
Venting a microwave range Hood over the existing vertical vent out gnans Kitchen & Bath Remodeling 0 05-31-2012 09:38 PM
Plumbing - Venting Bathroom - Please HELP garysacco Plumbing 4 12-09-2011 09:31 AM
Vertical dryer venting oatlord Appliances 4 04-04-2011 01:26 PM
