Venting Washer And Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-03-2015, 09:33 AM   #1
Rewards Points: 1,602
Venting washer and sink
I found this pic online, but it shows the two things I'm going back and forth with. Assume the leftmost pipe is the washer drain. Right now I just have that and the bottom pipe over to the right stack. I'm adding a sink between the two. My question is do I need the vent shown with the dotted black lines or just the center vent for the sink that goes over to the main vent? Hope that makes sense. Thanks for any help.
mikegp is offline   Reply With Quote
Old 12-03-2015, 06:22 PM   #2
Rewards Points: 1,860
What state are you in so we know what plumbing code applies.
Old 12-03-2015, 07:59 PM   #3
NY. Thanks.
Old 12-09-2015, 04:16 PM   #4
Anyone?
Old 12-09-2015, 05:22 PM   #5
They have their own thing going on in that state.
Old 12-10-2015, 07:10 AM   #6
I'm not really worried about code and legalities. I just want to know what the correct way to do it is. I want to make sure a trap doesn't get sucked dry or something have issues draining.
Old 12-10-2015, 07:27 AM   #7
Rewards Points: 127
Code usually describes the proper way to do things because it works
jimn01 is offline   Reply With Quote
Old 12-10-2015, 05:03 PM   #8
Under IPC it would not meet code because the stand pipe would need to turn into 3 inch size pipe once one adds the laundry sink into the line. That is why I kept my mouth shut.
Saying that what you propose would work but does not meet my code.
Connecting utility sink to washer standpipe not2quick Plumbing 5 02-20-2014 06:48 PM
washer & sink hookup... phantomvs Plumbing 3 09-11-2012 11:20 AM
Draining laundry sink into washer stack? glamgirrl Plumbing 33 12-31-2011 02:02 PM
How to add Utility Sink and Washer Drain to existing 4" obriendigital Plumbing 9 03-26-2011 06:39 PM
utility sink, washer drain simon Plumbing 4 11-14-2007 07:30 PM
