Venting Kitchen Sink Under Window - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2016, 09:04 PM   #1
jkk
Rewards Points: 335
Venting kitchen sink under window
My kitchen sink sits under a wide window. Receptacle boxes under window are 41" from floor, to bottom of window. With countertop height being 36", there's not way I can get the vent height to meet the 6" higher than sink requirement. I would think this is a common dilemma for sinks under windows. Other than using an AAV, which I'd rather not, are there other options?
My other problem is running the 1/5" vent up through double plate in a house with no eave. Getting a 22.5 or 45, in the attic, at top of that vertical vent pipe just above the double wall plate, seems like a job for a contortionist ...
jkk is offline   Reply With Quote
Old 02-05-2016, 09:10 PM   #2
Rewards Points: 3,180
Vent pipe for kitchen sink has a sweep 90 above the sink, goes a few feet, then another sweep 90 takes it up towards the roof, where it has another 90 then travels a few feet before another 90 takes it up through the roof.
That not work?
ktkelly is offline   Reply With Quote
Old 02-05-2016, 09:12 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 166
Run the vent and drain up the side, next to the window and run a horizontal trap arm to the sink location. At the plate line, drill up through the roof to vent the sink by itself.
Old 02-05-2016, 09:15 PM   #4
Rewards Points: 564
I had the exact same issue when I built my house. I put a provent under the windowsill. I put it in so that if I ever had to change it all I had to do was pull the windowsill out and I could unscrew it and screw in a new one. That was 25 years ago. I have never had any issues.
BayouRunner is offline   Reply With Quote
Old 02-05-2016, 09:16 PM   #5
Rewards Points: 18,784
Picture would be great.
"1/5 vent" Guess you mean 1-1/2" vent.
An AAV does not need to be higher then the sink.
What is it your doing that makes you ask the question?
Old 02-05-2016, 09:34 PM   #6
jkk
Rewards Points: 335
Yes, 1.5". I think i was confusing the situation where you join an existing vent, where the joint needs to be above flood plane. Since there is no ven yer, i guess i can use a tee at drain connection, go vertical a little bit and the run over to side
of window. My mistake.
The hard part is accessing the area above the plate. Very little room there.
My kitchen sink smells like sewer kasgirl Plumbing 7 11-23-2012 04:57 AM
Installing new Vent pipe for kitchen sink dtweiss74 Plumbing 1 10-21-2012 02:11 PM
Kitchen Sink Delimma.. shbhalla Kitchen & Bath Remodeling 3 08-28-2012 10:08 PM
Venting a sink pump WillK Plumbing 2 12-26-2010 01:21 PM
How bad/unusual is it for a kitchen sink under window to be off-center? Iron Petunia Remodeling 17 11-21-2010 06:33 AM
