Vent Coming Up From The Floor - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
Old 06-30-2017, 07:43 PM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 290
Re: Vent coming up from the floor
OK- Cut the vertical risers off, Remove enough material from each, then reconnect them using couplings. Abandon below the floor
An island vent is only for sinks and needs a foot vent- which you lack.
With what you have shown us in the video and picture, I'm surprised everything works.....
Old 06-30-2017, 07:48 PM   #17
Eventually, I may want to make improvements, but right now I didn't budget in enough $$ to allow for a plumber to come in and fix all the stuff. The horizontal 3 in pipes that you see in the video are heading toward the kitchen, I assume that the toilet would be vented there.
Jamesgary is offline   Reply With Quote
Old 06-30-2017, 08:26 PM   #18
Well that wasn't a vent pipe lol.....
Started to cut into it and I nearly started a great flood. No idea why this would need to be above the floor, but it is now below.
plumbing vent boilermaker27 Plumbing 5 09-26-2013 07:37 PM
Bridging--bouncy vibrating floor meature Building & Construction 15 02-05-2013 05:43 PM
Doing demo - plumbing coming through floor pcampbell Plumbing 12 09-28-2011 10:25 AM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
Replace forced air heat vent with radiant floor malfunction HVAC 9 02-05-2009 12:01 PM
