Is This A Vent Or An Additional Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-29-2016, 11:57 PM   #16
Rewards Points: 6,652
Originally Posted by Smahoney6 View Post
Ok so the drip drain isn't from the HVAC, it is the Water Softener drain.
Even then, you still do not want that plumbed into a closed DWV system. You want the Water Softener drain going into a utility sink, not directly tied.
Old 01-30-2016, 12:03 AM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 162
Draining a water softener to an indirect receiver such as a washer box is code compliant.
Tags
drain , laundry drain , vent
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 04:10 AM
1.5" vent for toilet with 3" drain? fulmar2 Plumbing 24 11-04-2012 10:06 AM
Vent line has goes UP, down, UP - can I drain lowest point? calphalon Plumbing 22 09-20-2012 09:06 PM
Can I split a main drain vent stack? -- SpinFly Plumbing 14 08-15-2012 10:32 AM
Advice to vent or not vent floor drain hellothere123 Plumbing 0 04-09-2011 09:58 AM
