Vanity And Top Placement. - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree9Likes
Old 09-08-2019, 07:51 PM   #1
Rewards Points: 32
Vanity and top placement.
Installing a vanity in a corner. As you can see the corner is not exactly 90degrees. Didn't expect it to be.
I'm putting in a quartz top.
1. How do I handle the discing between the vanity and wall? Because of the profile, I can't just put a spacer down the side to fill the gap.
2. Related to 1, how much if any of a overhang should I have in the wall side? I am planning on installing a backsplash and sidesplash.
Sent from my Pixel 2 XL using Tapatalk
moosehaed is online now   Reply With Quote
Old 09-08-2019, 08:06 PM   #2
retired framer
Rewards Points: 1,470
Re: Vanity and top placement.
I would sand the side so it it fit into the corner, I have also cut a slot out of the trim to apply a filler over to the wall
huesmann likes this.
Do not use flat bottom gables with scissor trusses.
Old 09-09-2019, 10:20 AM   #3
Rewards Points: 834
I like Neal's suggestion. Are you not having a backsplash?
huesmann is offline   Reply With Quote
Old 09-09-2019, 10:27 AM   #4
retired framer
And to get the right colour for that spacer I stole the top rail off the back of the cupboard, don't tell anyone.
Old 09-09-2019, 10:36 AM   #5
Two Knots's Avatar
Rewards Points: 4,873
Am I missing something? If you’re putting a quartz countertop on,
they should be able to fit the countertop to the side wall.
I’m sure they run into this problem a lot.
The space below will be fine, it’ll just need a vacuuming
occasionally with the hose attachment. good luck.
Gregsoldtruck79 and moosehaed like this.
Behind every clever man is an astonished woman!
*Joann*
Dogs love me, men fear me!
Two Knots is online now   Reply With Quote
Old 09-09-2019, 10:42 AM   #6
Rewards Points: 32
I'm trying to determine if the vanity should be up against the wall with no overhang of the quartz top, or if I should have the quartz overhang 1/2 in against the side wall.
If the top overhangs, then the vanity needs to be away from the wall.
I will have a back splash and a side splash.
Old 09-09-2019, 10:43 AM   #7
Rewards Points: 32
Going to have a back splash and a side splash.
Old 09-09-2019, 10:47 AM   #8
Rewards Points: 32
So are you saying, that instead of trying to copy all the contours of the cabinet to make a spacer, I should just cut a slot/notch in them on the side so the trim piece is flat ?
Nealtw likes this.
Old 09-09-2019, 10:55 AM   #9
Two Knots's Avatar
I think up against the wall is fine - with no spacer on the side of the vanity.
*Joann*
Old 09-09-2019, 11:09 AM   #10
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,418
As you can see ...
Choose a different vanity base.
Look for something with some extra for 'scribing' on the right.
TarheelTerp is online now   Reply With Quote
Old 09-09-2019, 01:14 PM   #11
Two Knots's Avatar
He already has the vanity and asking opinions on how to
do the countertop. Son just put in two bathrooms in his house
(DIY) He ran into this situation and ended the counters at the
wall, no scribing, no fill in - it looks very nice... and yes, he has
a space between the vanity and the wall.
moosehaed likes this.
*Joann*
Old 09-09-2019, 01:25 PM   #12
MarginallyQualified
He already has the vanity...
I know. I'll stick.
Old 09-09-2019, 01:31 PM   #13
Hammered Thumb
Rewards Points: 450
If it's a prefab top, the overhang will be determined for you.
Furniture-style vanities are meant to be held away from the wall, so there would be no issues with off-kilter gaps, qtips and band-aid wrappers stuck down the side, and painting in the future.
3onthetree is offline   Reply With Quote
Old 09-09-2019, 01:34 PM   #14
Two Knots's Avatar
moosehead, are you set on the sidesplash? I personally
like vanities without a sidesplash.
Here’s two pics of the vanity that I mentioned just ending at the wall.
counter dies into side wall without a sidesplash, just a backsplash - neat and clean.
If the counter TOP dies into the side wall, nothing can fall down next to the vanity.
Vanity and top placement.-19539868-f491-4175-863f-12d6704f2a37.png   Vanity and top placement.-a5180a05-d679-4a79-8d99-d0c0e7207242.png
*Joann*
Old 09-09-2019, 01:38 PM   #15
Rewards Points: 22
Word definitions, I drive myself bonkers with them...
There is no "over hang" on the right hand side of that vanity top. As the top will sit tight against the drywall to the right.
If the vanity sat 12 inches away from the wall to the right then yes, the vanity top on the right hand end would need "overhang" of about 3/4 of an inch.
As KT said, the top maker should sand the top to fit the wall on the right nicely. And that crack showing where the vanity now meets the wall, only the very short people in the home will see it. And the vanity is standing off of the right side wall anyway, because of the baseboard.
Two Knots and moosehaed like this.
Gregsoldtruck79 is offline   Reply With Quote
