Vanity Piping Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-27-2015, 05:02 PM   #1
Rewards Points: 4
vanity piping issue
Hi everyone,
my brother and i are replacing the vanity in our bathroom; however we have a slight problem and do not know how we can get the old vanity out without damaging the drywall behind the drain pipe because the drain pipe does not go out the back like normal. instead the drunk fools who built the house back 1993 ran the drain pipe wrong and it goes out the side.
any suggestions are very welcome!!
Mc55m is offline   Reply With Quote
Old 06-27-2015, 05:13 PM   #2
Retired Moderator
Rewards Points: 7,174
Cut the pipe about 1 1/2" from the cabinet side--if that doesn't clear it enough--cut it plush and plan on opening the wall to replace the T inside the wall
Old 06-27-2015, 05:43 PM   #3
Rewards Points: 582
yep what mikey said
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (06-27-2015)
Old 06-27-2015, 06:55 PM   #4
Rewards Points: 4
okay so yeah we had to use metal snips to cut the stupid piece aroundthe pipe
we got it out
now we have to get a new vanity because the one we got isn't long enough....my brother measured wrong....woops lol
thank you for the advice!
it is much appreciated!
The Following User Says Thank You to Mc55m For This Useful Post:
Old 06-27-2015, 06:59 PM   #5
Retired Moderator
Pictures always help----plumbers have a few specialty tools for removing PVC from fittings --A Ram bit is one of them---let us see what you are up against--someone here will have an answer.
ben's plumbing (06-27-2015)
Building HVAC vent into bath vanity nolamar Carpentry 35 02-10-2018 07:58 PM
Enlarging vanity and P trap problems wildcard585 Plumbing 2 05-10-2011 07:34 AM
small gap between vanity and wall, how do i screw it in? cantgetenuff Building & Construction 8 03-09-2011 11:15 AM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 04:56 PM
Piping Layout for New Bathroom structman Plumbing 2 02-23-2010 05:24 PM
