Valve On Water Line To Water Heater Dripping A Lot . . . - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2015, 07:17 PM   #1
Rewards Points: 36
Question
Valve on water line to water heater dripping a lot . . .
Hi,
I am a brand new home owner so please understand my lack of knowledge :P
There is dripping coming from the water line that runs to my water heater (NOT the overflow valve).
It is coming from what appears to be some sort of drip line. I have attached an image.
I never noticed water dripping from there before, but it is now dripping at a rate of several times per second - thankfully, into the drain in my floor. It still has me concerned though.
Any ideas why it might be doing that? How can I get it to stop?
Michaelangelo is offline   Reply With Quote
Old 03-19-2015, 07:23 PM   #2
Rewards Points: 582
that looks like some sort of relief valve..get a picture of the area with valve and heater togeother.. if it is relief valve should not be reduced in size and certianly not like that...sorry
Old 03-19-2015, 07:25 PM   #3
Rewards Points: 3,454
Where exactly is it leaking from. Can't tell by the pics, but it looks like a drip (could be solder, idk) forming at that one solder connection and then it drips down the fitting.
jmon is offline   Reply With Quote
Old 03-19-2015, 07:26 PM   #4
Rewards Points: 36
Sure, here's a pic of the valve along with the pipe that leads to the top of the water heater.
Old 03-19-2015, 07:27 PM   #5
Rewards Points: 36
It's the clear line on the valve that is dripping. Capturing excess water is clearly its purpose but it never really dripped before and now it is constantly dripping at a fairly high rate.
Old 03-19-2015, 07:46 PM   #6
Rewards Points: 6,236
To be perfectly honest I have no idea what that valve is for or what purpose it serves. To be located there pressure relief doesn't seem right. Seems if it has a line on it maybe it's supposed to drip.
Entering your general location can help with answering a lot of times
Old 03-19-2015, 07:46 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 258
Perhaps an odd looking trap primer?
Moving to plumbing
The Following User Says Thank You to TheEplumber For This Useful Post:
Michaelangelo (03-19-2015)
Old 03-19-2015, 07:49 PM   #8
Not really sure what it is. Looks like some sort of relief valve, check valve, or backflow preventer. If it's a backflow preventer it's designed that way. If it's continually dripping it may need to be replaced.
Wait for Ben or e to respond they'll know.
The Following User Says Thank You to jmon For This Useful Post:
Old 03-19-2015, 08:07 PM   #9
Plumber
Rewards Points: 258
This is why I'm thinking a primer
http://www.jrsmith.com/product.aspx?...ic+Trap+Primer
Any writing or ID marks anywhere?
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
jmon (03-19-2015), Michaelangelo (03-19-2015)
Old 03-19-2015, 08:15 PM   #10
Rewards Points: 36
Could be a primer or backflow. It doesn't have any markings on it. It drains into a green tube in the floor near the in-floor drain.
I guess I shouldn't be too concerned but since its behaviour has changed it may need replacing. Whatever it is . . .
Old 03-19-2015, 08:21 PM   #11
Rewards Points: 582
I have not seen them around here ...good thought..
Old 03-19-2015, 09:10 PM   #12
Mad Scientist
That looks like a trap primer to me. Usually they let a tiny bit of water flow down the drain any time there's a fluctuation in the water pressure, as from opening/closing faucets, flushing toilets, etc. If it's letting drips of water through constantly, it's gone defective. You can either replace it, or just remove it and remember to pour a bit of water in the floor drain periodically to keep the trap from drying out.
McSteve is offline   Reply With Quote
The Following 4 Users Say Thank You to McSteve For This Useful Post:
ben's plumbing (03-20-2015), jmon (03-19-2015), oh'mike (03-20-2015), TheEplumber (03-19-2015)
Old 03-20-2015, 06:09 PM   #13
Rewards Points: 1,942
Its a thermal expansion control device. Relieves the pressure through the drip. Instead of a expansion tank someone opted for this.
Brand new water heater TPR valve spraying fetzer85 Plumbing 50 03-20-2013 11:32 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Question on return line for water heater daluu Plumbing 10 09-09-2012 10:38 PM
Leaky ball valve at incoming water line Bipin1948 Plumbing 5 10-03-2011 05:21 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
