Is This Valve Installed Correctly? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2015, 07:28 PM   #1
Rewards Points: 14
Is this valve installed correctly?
Question for any professional plumbing tradesman lurking out there on this forum that is familiar with bronze fittings and can clarify a question regarding the installation of this particular check valve;
This following is a picture of a KITZ Class 125 Y Pattern Swing Check Valve my plumber has installed in my hot water system. The water flow through the valve is going down, not up. I am having my doubts it is installed correctly but my plumber says it is.
Question: Does the positioning of this valve in this position and direction allow it to work properly?
hr2pilot is offline   Reply With Quote
Old 11-03-2015, 08:23 PM   #2
Rewards Points: 450
Doesn't seem right and it looks like the manufacturer agrees. Basically the way that is it is swung open all the time and gravity will tend to want to keep it that way. If the fluid was flowing up then it would be ok. Here is a link to the site and a quote from the bottom about how it works. https://www.kitz.co.jp/english2/type_checkvalve.html
♦Swing Check Valve
A hinged disc assembly is suspended from the body to allow it to move freely. This configuration minimizes pressure loss and eases fluid flow. Swing check valves can be used for either horizontal or vertical (fluid flowing upward) pipe layouts.
KC_Jones is offline   Reply With Quote
Old 11-03-2015, 08:27 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,642
The gate will be swinging open. It will not function likely. That valve should be installed horizontal not vertical.
The Following User Says Thank You to joed For This Useful Post:
Chrisathome (11-06-2015)
Old 11-03-2015, 08:32 PM   #4
Rewards Points: 5,590
According to this link it is to be installed horizontal.
http://oslandpiping.com/kitzvalves/k...stechdata.html
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 11-03-2015, 08:58 PM   #5
Rewards Points: 14
Yes, these are all the same thoughts I had. Thanks for the links to the proper installation instructions.
Will be having a bit of a chat with my plumber.
pipe sleeve installed correctly? dja3137 Plumbing 2 07-29-2012 06:50 AM
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 05:00 PM
Do the fittings need to be sweated before being installed on shower valve? twilightcall Plumbing 5 08-24-2008 11:47 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
